zero gauge
Username: Insearchofbass
Post Number: 8791
I need a amp kit cheap that is zero gauge with distribution block and a deal on the 0 gauge wire by itself because he needs 35 feet total...suggestions please
Username: Stateprop486
PA
Post Number: 1394
how much is cheap? paul still has 40ft of 1/0 wire left. i believe. this is a great kit Kicker PKD1, 95.95 on ebay, comes with everything you need besides RCA. I dont know if thats a little pricey for u but just suggesting it....
Post Number: 8793
well in all honesty its for my cousin and i doubt hes going to want to spend 100 bucks so what I thought might work is buy the amp kit first and ground it to the chassis and then later he can buy the second run of zero gauge...so based on that idea any suggestions...I was going to order the cheaper line stinger kit but it doesnt come with a distribution block and he needs that because the kicker 750.1 probably doesnt accept 0 gauge plus my bro said the rcas are a bad idea from stinger
PA
Post Number: 1396
did you look on www.knukonceptz.com there stuff is good too. i think they have 1/0 gauge kit for $60.
Post Number: 8794
I know KnuKonceptz was the wire I was going to use but my cousin wants to compete in rookie 1 and they dont let you have over 0 gauge
Username: Tejcurrent
Post Number: 1267
It's the same thing boss. 1/0 is like 0, 2/0 is 00, 3/0 is 000, 4/0 is 0000.
Just because it's literally more metal doesn't mean it is classified as 1/0- or zero guage.
Username: Somedonniedude
Illinois United States
Post Number: 1367
Why do you need 2 runs of 1/0 for a zx750? I'm guessing just to save money in the future?
Username: Rovin
Post Number: 13510
SOUND QUEST by stinger has wires at a econo price but mind u copper content is not true - like their 0g is more like 2g ...
A pic is worth 1000 posts!!
Post Number: 15778
Yup I still have 40' of 1/0ga if you're ever interested.
I also have 4ga and 8ga.
And 2ga.
Username: The_image_dynamic
San Diego, California
Post Number: 3703
Double up Paul's 4ga and you have 3/0
Post Number: 1374
How do you figure that?
Post Number: 8800
"Why do you need 2 runs of 1/0 for a zx750? I'm guessing just to save money in the future?"
yeah we want to save money on wire in the future but one run is for the power wire to the battery and another run is for the ground to the battery (better current flow) but with 80 amps I doubt it will improve much compared to just the chassis...down the road thats a different story (upgrades) and thats why my bro suggested a zero gauge ground to the battery
Username: Basebalz13
Moneta, Va Usa
Post Number: 421
get pauls wire, i love my hyperflex from kicker though =]
Post Number: 8803
how much is your wire Paul...he can only use up to zero gauge
Username: Nd4spd18
Northwest PA
Post Number: 7289
Post Number: 8805
"It's the same thing boss. 1/0 is like 0, 2/0 is 00, 3/0 is 000, 4/0 is 0000.
Just because it's literally more metal doesn't mean it is classified as 1/0- or zero guage."
but it has 1/0 printed right on the wire and I didnt want him to get called out for being over the rated wire limit in a competition ...since 0 gauge is the limit...isnt 1/0 higher than zero gauge
PA
Post Number: 1422
no 1/0 is saying 1 gauge wire turning into 0 gauge wire. 0 gauge is the highest....
Post Number: 8806
ok now KnuKonceptz klm wire is looking like the way to go because if we can cut back the wire lengths to 15 feet each from the battery that would only be 52.50 plus 8.50 shipping= $61.00 for 30 feet of 1/0
Post Number: 15793
Yeah I paid $2/ft for the wire I have so it would be cheaper to go with Knu. Mine would be $60 before shipping.
I'll hold onto it.
Post Number: 8808
cool Paul
Post Number: 3716
4 guage conductor diameter = 0.2043
3/0 guage conductor diameter = 0.4096
