Silver Member Username: Dharm_ramPost Number: 135 Registered: Dec-07 | I have VSU & I am getting star one on echo7, but unable to get star plus in autoscan. TP 11959 is already there (as per lyngsat) but still star plus is not coming up in scan. Any suggestions please? |
Silver Member Username: Madflea168Post Number: 389 Registered: Jan-08 | 11959 is supposed to be on 118 where most of the international are right now, I guess you are just lucky with your setting to pick up star one if you did not change your lnb. if you did not, I am not so sure that you will able to capture with the 119 lnb, 119 and 118 have different freq and most likely, 118 require bigger dish like 30" for better signal since broadcast at lower freq. |
Silver Member Username: Dharm_ramPost Number: 137 Registered: Dec-07 | I have bigger dish 30" and 119. Here is the link where it says it is on 11959 http://www.ly*ngsat.com/packages/dish119.html I don't understand why I am missing star plus? |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1432 Registered: Jan-08 | dharm try to delete sat and rescan it |
Silver Member Username: Madflea168Post Number: 394 Registered: Jan-08 | 118/119 on lyngsatdotcom is listing together, if you scroll down to freq 12224, you will see tp starts to #1 which is 119's line up. 11959 IS on 118's line up. |
