Anonymous | I i have two JL 15" w3's and i was told that a JL 500/1 amp would push them nicley. Does anyone know a place online that i can get an amp like this for under $380????? Also does anyone konw if a sealed or ported box would be better for these subs and where i can get a good one online????? Thanks |
New Guy23 Unregistered guest | try ebay |
New member Username: Jiggaman3105Post Number: 1 Registered: May-04 | ebay would be a good place but too much hassle. try getting a different amp since ur on budget. i would say a PG Octane R 8.0:1. jus about $420. itll give the bang for ur buck....or hond the other hand, jus spend ur money on the jl 500/1. its worth every penny. u cant be cheap when shopping jl. |
New Guy23 Unregistered guest | it took me awhile but i found a brand new jl 250/1 amp on ebay for $195. |
Silver Member Username: Jonathan_fGA USA Post Number: 219 Registered: May-04 | A 250/1 won't push those subs very well at all. |
New Guy23 Unregistered guest | I wasnt recommending the 250/1....just saying their are deals to be had on ebay if you look hard enough, getting a $400 amp for $195 is quite a bargain, and if he's lookin for the 500/1 I'm sure there is a good deal there too as well |
Anonymous | He could also get a great deal here for 419.00 www.acaraudio.com |
