so i was tryin to put sum polyfill in my box and i removed only 5 out of the 8 screws and the other 3 stripped whats the best way to remove them? i even try buyin that stripp screw bit remover....it made a big circle now... thanks guys
I usually use a hacksaw to cut a slot but you probably countersunk yours. In that case, and angle grinder could cut a slot or an air grinder might work better due to the smaller wheels which means less damage to the box.
i was removing the screws that held the sub in place....i got 6 out of 8 now....i had to take the rubber things off around the subs that keeps the air from leaking out....then i used pliers and twisted the one out...now i got 2 screws left that i cant get too....
Oh. I think Chad's method is probably the way to go then. Just check the size of one of the screws you got out against a drill bit and choose the bit that is slightly smaller. You want to be able to remount your sub so don't choose a bit that's any bigger than the shaft (probably not the right term).
lol phew good news, i pry out the remaining 2 screws with the back of the hammer part....wow im so lucky...lol thanks for the help anyways guys...lol thats messed up chad u laughed
i believe we all laughed inside... but thats good you got them out.. Stripped screws suck.. i got this free Stripped screw set from handy man club.. they work pretty good
