Will one 1000/1 work to run two 12W7 amps across all demands for the subs (i.e. peak, RMS, continuous). I want to run them in parallel.
One 1000 will run 2 W7's, I did this till I had money for another 1000.
teflondog
the jl 1000/1 is a very good amp. it is way underrated; mine was tested at 1497 watts. it will definitely run two 12w7's. it's enough to blow your eardrums out. what i like best about jl amps is that they're voltage regulated so they put out about the same wattage at any voltage. at 12 volts they still put out around the same as 14.4 volts. you don't need any more power unless you want to compete for spl.
