Which Amp?
Username: Ridnclean
Washington USA
Post Number: 8
im trying to figure out which amp will be better with the proper electrical.
1. MA Audio 5082HX
http://ampguts.realmofexcursion.com/MA_5082HX/
2. Memphis 4kW
thanks for your help
Username: Nd4spd18
Northwest PA
Post Number: 7099
Both of those are low quality amps and will draw a lot of power (inefficient).
Username: 04redmach1
Lagrange, GA USA
Post Number: 1719
If you are wanting an amp that does close to 4K, the Sundown 3000D or RD 3250.1 would be a good choice. I will elp you if wanted, you can email me.
Kevin
lowhz01@yahoo.com
Username: Ridnclean
Washington USA
Post Number: 16
email sent to you.
Username: Nd4spd18
Northwest PA
Post Number: 7129
Both of those amps are a world ahead of the two you listed. And Kevin is a good guy to buy from in terms of service and price.
Username: 420alldaylong
Post Number: 3451
2 AQ2200D
AudioQue.com
Username: N2audio
Lawrence, Ks USA
Post Number: 1526
since when has memphis produced low quality amps?
Username: Juliob
Santo DomingoDominican Re...
Post Number: 5253
opti he's saying that because a good amount of samples.. failed when driven at lower voltages.
IMO they're still good... it depends how cheap you can get them.
