Gold Member Username: AsharfiPost Number: 1908 Registered: Aug-06 | Here are the latest updated bins for all the Pansat models that are supported by Blacklist. All DN & BEV UP! download from |
Silver Member Username: Desi_mundaPost Number: 136 Registered: Nov-07 | should we convert to lazma? | |
Bronze Member Username: Freedom_ritesMontreal, Qc Canada Post Number: 25 Registered: Jan-08 | YOU CHOICE... IF YOU USING B-75 . BINS ARE OUT For Pansat 2500/FLU converted to 2700 Use only on converted receivers. DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones Only USE IT ON B-75!! DO NOT USE IT ON PUFF Read the instructions properly in the section you have chosen. PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS. TURNOFF THE AUTOROLL |
Gold Member Username: NydasPost Number: 9546 Registered: Jun-06 | Everything for 2500/Flu to 2700 conversion in one package. Instructions included. Either b75 or PUFF or PUFF_ LMZA http://public.box.net/2500_full_kit You must select whether you want to have the old b75 files or PUFF files or PUFF_LMZA FILES. If you have b75 boot, you must convert to PUFF boot to use PUFF BINs or PUFF_LMZA BOOT to use LMZA BINs. Read the instructions properly in the section you have chosen. PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS. |
Silver Member Username: Bill038Post Number: 609 Registered: Sep-06 | If you listen to nalin, the wicked witch of the north, she will kill your box, send you to hacked sites and turn you in to DN. Check her post counts, that is really the number of boxes she has killed. Do you know when she is going to kill a box.......................The next time she posts and someone takes her advice. Stay afrom her advice, she is here to send you to hacked sites and kill your fta box. |
Gold Member Username: NydasPost Number: 9569 Registered: Jun-06 | Could somebody please cal Pest control? | |
Gold Member Username: NydasPost Number: 9570 Registered: Jun-06 | I RECOMMED LZMA Everything for 2500/Flu to 2700 conversion in one package. Instructions included. Either b75 or PUFF or PUFF_ LMZA http://public.box.net/2500_full_kit |
Silver Member Username: Bill038Post Number: 616 Registered: Sep-06 | If you listen to nalin, the wicked witch of the north, she will kill your box, send you to hacked sites and turn you in to DN. Check her post counts, that is really the number of boxes she has killed. Do you know when she is going to kill a box.......................The next time she posts and someone takes her advice. Stay afrom her advice, she is here to send you to hacked sites and kill your fta box. |
Gold Member Username: NydasPost Number: 9578 Registered: Jun-06 | Can anybody send for the pest control?
Bronze Member Username: BolingPost Number: 24 Registered: Oct-07 | I'm having problems with my pansat 3500/SD, ever since I installed X-05BL_080328_376_api_nocard patch that was released on 3/28 i'm getting a blank screen. Any idea what the issue is or how to fix it? Thanks in advance =) |
Platinum Member Username: LklivesPost Number: 15007 Registered: Jan-06 | It could a simple fix, like a reboot off for 2-3 minutes with rear switch...if not start, then check your receiver antenna settings in menu, often they change by themselves when uploading a new file..reinput your written down saved ones, that correspond to your hardware up on the roof.. | |
Gold Member Username: NydasPost Number: 9689 Registered: Jun-06 | Pnasat 3500SD BINs. Version 375 was killer. It was replaced by 376. No bad reports on the 376. If you did install the 376, you will find that the autoroll take a very long time - Keep it on after rescanning, and eventually the autoroll will work. As a last resort, install the factory BIN and then install the 376 and rescan. [link removed] |
Silver Member Username: BorinickPost Number: 360 Registered: Mar-07 | Good afternoon nalin or LK got this problem with a pansat 2700a orignal it has the news bin 260bl but works for while and then it truns off and on and then you can make it work .How should it be fix | |
Gold Member Username: NydasPost Number: 9695 Registered: Jun-06 | Nick: I answered you somewhere else. | |
Bronze Member Username: BolingPost Number: 27 Registered: Oct-07 | can you please tell me which is the factory bin I should Install Pansat 3500S_061217_B80_v02_api ? boot_ltc80__06_1019? |
Gold Member Username: NydasPost Number: 9699 Registered: Jun-06 | Pansat 3500S_061217_B80_v02_api |
