Has anyone got or fitted a Clifford Concept 500 G4 at all please?
Do you have the warn away feature from a proximity sensor with your alarm, i'm trying to fit one at the moment, but i cant get it to 'warn away' Chirp.
I have had it on a Concept 600 system but i'm not sure if it is possible on a 500.
does anyone know either way, to put me out of my misery.
hi, I've got the concept 500 fitted to my van,with the sensor fitted, if anyone gets too close it chirps, the alarm was already fitted to the van so i don't know any more than that, i've got the handbook that came with it if thats any use.
