Username: Masterstylz Post Number: 39 Registered: Feb-06
Sunday, March 30, 2008 - 05:51 GMT VS2000 Lite Ok I got the new bin from totalfta. I tried to update the receiver using Loader2. It wouldn't update after several tries. it currently has the march 5th bin. after turning on, it should start updating but instead i get Loader Error window. What can i do to update the receiver?
Username: Madflea168 Post Number: 385 Registered: Jan-08
Sunday, March 30, 2008 - 07:20 GMT go try other sites and download the bins again. many people here do not trust that site anymore. good luck.
Username: Plymouth Quebec city,
Quebec
Post Number: 1375 Registered: Jan-08
Sunday, March 30, 2008 - 12:20 GMT Lord go to viewsatusa.com/support for Loader and factory bin
Username: Masterstylz Post Number: 40 Registered: Feb-06
Sunday, March 30, 2008 - 14:20 GMT I got the loader and factory bin for viewsatusa.com. But still get the same error message, "Error Updating."
Username: Lklives Post Number: 14985 Registered: Jan-06
Sunday, March 30, 2008 - 14:58 GMT Check cable and connections...possibly reverse the cable..and provide more detailed info u really expect detailed responses.. how to use the receiver... [link removed]
Quebec
Post Number: 1385 Registered: Jan-08
Sunday, March 30, 2008 - 15:01 GMT Ritalin time I think LK is a little bit agited this morning Ritalin or Prosac MMMMMHHH!
Username: Masterstylz Post Number: 41 Registered: Feb-06
Monday, March 31, 2008 - 02:43 GMT Details? ok... I have a Viewsat Plat Lite (VS2000) Any suggestions?
Username: Masterstylz Post Number: 42 Registered: Feb-06
Monday, March 31, 2008 - 02:45 GMT Oh and yes I did power off and on the receiver between picture 4 and 5.
Username: Luser Post Number: 170 Registered: Nov-07
Monday, March 31, 2008 - 03:38 GMT Have you used this cable before? It must be a null modem cable.
Username: Lklives Post Number: 15002 Registered: Jan-06
Monday, March 31, 2008 - 03:44 GMT SENDING ZRQINIT message error...that was the missing link in your previous posts.. U have a communication problem between your receiver and computer...either bad/wrong cable or comport...check connections, try reerse cable...make sure its the right cable that came with the receiver..don't use USB ports unless u have an adapter and drivers...try all comports...check baud rate...etc.. U can also google that error message for additional hints to try..
Quebec
Post Number: 1400 Registered: Jan-08
Monday, March 31, 2008 - 12:33 GMT Lord keep your receiver off (rear switch) Check in tool and choose Port Com1 before Click PC to STB and Switch on receiver Take the Loader and Factory bin to viewsatusa.com for your box Good luck
Username: Nqarni Post Number: 31 Registered: Feb-08
Monday, March 31, 2008 - 15:42 GMT I had the same prob couple of mths ago. I was using Serial cable. Must use Null cable. they both look same.
