bhangel..thanks bro..loader?I,m new to this. Is this different than facory file.bro...do know any link to the loader file.Secondly, my sv4k deosn't respond to the remote,so in this case I can't use USB.Null wire is the only option right? Please tell more about uploading process. After connecting sv and computer.What,s next? Please Help me. Will be greatful.
Look at Sonicview sections - discussion and Files at: http://www.Ftatalk.com
Get SV4000_Factory_20061229.bin Downloader_v0201.exe SV4000_V0223P Charlie&Beverly FIXED.bin
Loading SonicView with Null Serial Cable
1. Download SonicView Downloader v0201 and Current Working Bin Sonicview SV4000
2. Place all files in the same folder as loader is located.
3. With SV-4000 turned off at the back, connect null modem cable from FTA box to PC/laptop.
4. Start loader program, Click STB -> Connect Config for Com 1 or any com port # that you PC is preference.
5. Click STB -> Download file (PC->STB) directing the downloader to the file you are wanting to load.
6. Window appears entitled Data Transfer -> Turn VS 4000 on from the rear power button and do not touch it until transfer is complete and SV4000 reboots.
7. Turn off SV-4000 at rear, disconnect null modem cable
