Bronze Member Username: Rafiq128Post Number: 54 Registered: Feb-08 | Hi, sada assalam o alaikum , i have one channel 1553 or 553 its tree house tv for kids i am not getting on nfusion . can you check its comming to your nfusion. its nimiq 1 91 channel 553 its its comming then tell me how i can get it. like tp etc. thanks |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1391 Registered: Jan-08 | Bhatti do you know how enter a TP freq and scan it I'm sorry for you, you dont have this channel again |
Bronze Member Username: Rafiq128Post Number: 56 Registered: Feb-08 | plymouth, thanks, i am not very good at dish i am new and need help. this channel is for kids its not scanning on my satellite. i don't know how to do it. thats why i am asking. thanks any how i really appriciate it. i have nfusion receiver. i know sada have this receiver. thats why i was asking him |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1399 Registered: Jan-08 | Try to learn your box on this site: http://www.kashbrand.com/Nfusion.html |
Bronze Member Username: Rafiq128Post Number: 57 Registered: Feb-08 | plymouth. thank you very much for the site . all your help is appriciated from my heart. thanks once again |
Gold Member Username: Saqeeb9000Post Number: 2998 Registered: Oct-07 | sorry bhatti for late response.. i was busy yesterday... ok yes i am getting channel 1553 kids channel on nfusion reciever.. freq is on 91 dish, frq 12356, hor,20000 how to get this channel on nfusion? press menu, installation, channel scan , click on add tp, for frequency enter 12356, pol choose auto, symbol rate , choose 20000, then click on search channel , after its done , press exit button. let me know if it worked for you enjoy.. |
Bronze Member Username: Rafiq128Post Number: 62 Registered: Feb-08 | hi, sada i tried your instruction its still not working any other way to try. |
Gold Member Username: Saqeeb9000Post Number: 3000 Registered: Oct-07 | what happend when u click on search channels.. it doesn't give u any chanels? are u choosing the right sat name? tell me exactly what are you doing and whats happening? |
Gold Member Username: Saqeeb9000Post Number: 3001 Registered: Oct-07 | if you still cann't make it to work, try to do a factory reset and rescan all the channels......for each sat.. |
Bronze Member Username: Rafiq128Post Number: 64 Registered: Feb-08 | i put the frequency 12356 and then tried 12355 pol auto then hor. s rate 20000. i click on seach channel. it says search fail. i tried 2 times both time it says search fail.. sat is nimiq 91, i put the correct sat. |
Gold Member Username: Saqeeb9000Post Number: 3002 Registered: Oct-07 | ok here is what i am doing..menu installation, click on channel scan , now choose 91 sat, then don't change any thing on anteena setting scroll down , click on add tp, put freq,pol auto, symbol rate 20000 then search channels.. working for me..... or do a factory reset and scan channels again.. |
Gold Member Username: Saqeeb9000Post Number: 3003 Registered: Oct-07 | 12356 and then tried 12355 posted by bhatti? why did u choose two diff freq? |
Gold Member Username: Way2smartWww.Desifta.com Post Number: 1449 Registered: Oct-06 | sada bhai come over to desifta some time.... |
Bronze Member Username: Rafiq128Post Number: 65 Registered: Feb-08 | on lyngsat the frequency for 553 channel was 12355 thats why i tried that one. how to do factory reset. thanks |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1409 Registered: Jan-08 | Bhatti the difference can be + - 2 Sada how do a blind scan on Nfusion? |
Gold Member Username: Saqeeb9000Post Number: 3006 Registered: Oct-07 | u can not do a blind scan with nfusion, bhatti go to menu, system setting, factory default,.. this will delete all the channels.. then choose sat and scan the channels. |
Bronze Member Username: Rafiq128Post Number: 67 Registered: Feb-08 | sada thanks for help. i tried as you said , but still not getting the channel i want, so i gave up, i told my kids watch other channels until i get this channel. some body said may be my dish is moved so i might check the dish in few days. how many channels you are getting on nimiq 1 can you please reply. i am getting 231 channels on this sat. |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1429 Registered: Jan-08 | + - 420 channels Bhatti Where are you locate(State only) and give me size of your dish |
Gold Member Username: Saqeeb9000Post Number: 3007 Registered: Oct-07 | 91... 427 cgabbeks 82 .. 79 channels |
Bronze Member Username: Rafiq128Post Number: 68 Registered: Feb-08 | i am in toronto (mississauga) canada. some body told me may be your dish is moved. so i will have to check my dish in few days.plymouth and sada thank you very much for your help. thanks my dish size is 20" its bell dish with 2 lnb's 82 & 91 |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1434 Registered: Jan-08 | Bhatti buy a cheap satellite finder, i have one and this is the best for aligned your dish without brought receiver and tv on roof. Just to install between LNB and receiver cable on dish. Look what it is: http://www.sadoun.com/Sat/Products/Accessories/Meters/SF95L-DSS-FTA-Satellite-Si gnal-meter.htm |
Bronze Member Username: Rafiq128Post Number: 69 Registered: Feb-08 | thanks plymouth, they are selling for $10.00 in toronto, i will buy it and try it. i am not a dish or computer guy, i am learning all the time. so your help is appreciated from my heart. thanks again . |
