Gain setting
Username: Diehlerman
Post Number: 26
getting ready to set the gain on my amp.....when I go to subwoofer tools.com and get the volts it needs to be would I use the rated rms or what is on the birthsheet?
Username: Nd4spd18
Northwest PA
Post Number: 6917
I would just use the rated..... you will not get every last watt anyways and you never know how precisely accurate a birthsheet is.
Post Number: 28
oky doky
Username: Nd4spd18
Northwest PA
Post Number: 6936
Actually let me revise that....... if it's an amp thats known to be very underrated (I'm thinking of the rockford power series in particular) then you could go higher.
Post Number: 34
its the kicker zx 750.1.....birthsheet says 930
Username: Nd4spd18
Northwest PA
Post Number: 7098
I'd still do 750....... that 930 is probably at 14.4 volts.
Username: 420alldaylong
Post Number: 3456
I thought Kicker amps were 12.5v or 12.8v to get rated power. Hell I can't remember to many companys out there.
Username: N2audio
Lawrence, Ks USA
Post Number: 1525
the 750 will probably do rated power at 12.8, but I agree with MS that using 750w to set the gain would be the better way to go. That way it's known that under the amp won't clip under any circumstance. Besides - what's the difference between 750 and 850?? Nothing audibly, just more stress on the amp.
Username: Nd4spd18
Northwest PA
Post Number: 7135
^^^^ Well said thats what I was meaning to say.
Post Number: 36
ok....now I have another question on the matter. the prior was what I put in my girlfriends jeep. but, I'm getting ready to buy the audioque 1200d to push my 2 12" CVR's would I just use the 800 I need to get the voltage? or how would I go about setting the gain without hurting the subs?
Username: Nd4spd18
Northwest PA
Post Number: 7152
I would use 1200...... those subs can take a little more than rated as long as it is clean power. That is the key.
As long as you don't do anything dumb like use bass boost, boost bass with EQ settings, etc it will be all good.
Post Number: 37
ok......yea I never use the bass boost, would the bbe settings be considered boosting the bass?
Username: Nd4spd18
Northwest PA
Post Number: 7163
No that is not bass boost.
Username: Big_edge_head
Milwaukee, Wisconsin MY SUBS GET ...
Post Number: 1816
The bbe is a nice feature. I have mine on +1 on my premier 780. What HU do you have?
Post Number: 41
its an alpine cda-9856. (a little older model)
Username: Nd4spd18
Northwest PA
Post Number: 7181
That DOES need to be off when setting the gain though. Along with any other sound processing features.
Post Number: 44
yup, ten-4. but, hypothetically speaking if I were to buy an amp that produced more power than I was wanting to give my subs would I get the volts for the the wattage I'm wanting and not the volts for the rated power of the amp?
Username: Nd4spd18
Northwest PA
Post Number: 7203
Yeah you would use the max amount of power you want it to produce
Post Number: 45
ok cool...just wanted to make sure for future reference
