Nalin, I've successfully converted my 2500-2700 to PUFF. All Int'l Channels at Echo 9 are gone and left with mainly local TV channels & a couple of Int'l channels. Someone told me they changed to Echo 7, so I switched to Echo 7 and did blind scan, still the same. Do you know where did all those Int'l Channels go now?
I never bother to change it because I could see those channels (not all) under 2500-2700. Of course I have no choice now. Anyway, once I change a new LNB, what do I hv to do next? Do I still get those channels from Echo 7 or Echo 9? Please enlighten.
Note that they have moved to another satellite at 118.7 (Anik 3) - not to 119 (Echo 7). There are now a dozen thread in this forum alone about how to and types of LNBs for 118.7/119 scanning.
Thank you Nalin. I guess those Chinese channels also moved to this new satellite Anik3. Do I need to change the LNB in order to scan those channels back on Anik3? There are many different LNBs in the market, which is should I buy? My current one is a single LNB but don't know the model or type. Please assist.
