Where are the channels?
Username: Top2000dogg
Post Number: 89
how do I get the channels after the new bin has been downloaded? i get most of them but am also missing a bunch of them as well such as MTV, USA, TBS and alot of the cinemaxs and other channels, what happened and how do I get them back?
Username: Impala1977
Post Number: 209
You have to scan the sats. Depends also in the settings in your stb, your dish lnbs or if you have any switches in between. Give more info then someone can help you out.
Post Number: 91
what is the stb? and what switches?
Post Number: 92
these are my settings
My Box is a Megasat YT6688
Sat 1 - T-7/ku
LNB Type - Standard
LNB Local-Freq - 10750
22khz - off
Diseqc - off
Legacy SW - none
Skew - -45
TP - [1] 11950 V 8.684
Positioner Setting - Disable
Satellite Scan - all
Sat 2 - Echo 7/ku
LNB type - Dish-pro
LNB Local-Freq - 11250
22khz - off
Diseqc - #1
Legacy SW - none
Skew - -45
TP - [1] 12225 V 20.000
Sat 3 - Echo 8.10/ku
LNB type - Dish-pro
22khz - off
Diseqc - #2
Legacy SW - none
Skew - -45
TP - [1] 12224 V 20.000
