MY VS Ultra - not updating
Username: Moneyguy
I was trying to load the new files, and as I was doing it, it usually tells me "DO NOT POWER OFF" and then it disappears and restarts automatically. This time it froze on that "DO NOT POWER OFF" screen and eventually when I powered off, now the display on the sat show dashes, no digits.
can anyone help me fix this, thanks.
Username: Nydas
Post Number: 9642
Since it is showing dashes - nightriders - you can revive it using a factory BIN.
Get ready to load the factory BIN with your right hand on mouse. Turn receiver on and immediately click on mouse to write. You may even do th ereverse by clicking on "write and then immediately switching on. You might have to try it several times to get the load. Eventually you will load the latest BIN and do the full setup.
You might also want to look at
VS Ultra FAIL FIX.zip
avaialble at
[link removed] in th eviewsat discussion or file section.
Username: Moneyguy
thanks for the reply. Do I have to be a memeber of the site to get the file? is there any way to get it through this forum.
Username: Nydas
Post Number: 9651
You will probably need to be a member.
Username: Moneyguy
thanks. Where do I get the loader
Username: Nydas
Post Number: 9653
I don't understand why you keep on asking.
Become a member at:
http://www.ftatlk.com. Then look there for your needs
Username: Nydas
Post Number: 9654
I should be
[link removed]
Username: Moneyguy
thanks...became a member. and found it . you were a great help. I will connect the sat and load the fix file.
Username: Bailey1
Viewsat help....?
