Bronze Member Username: LoikkuPost Number: 12 Registered: Dec-05 | Somebody help me ?????? |
Silver Member Username: DimwittPost Number: 520 Registered: Aug-06 | www.howtofta.com/viewsat/knight-riders-or-flashing-lights-on-front-panel/ |
Bronze Member Username: KayossPost Number: 26 Registered: Feb-08 | Take your medication! |
Platinum Member Username: LklivesPost Number: 14956 Registered: Jan-06 | Dashing (----) nite rider lites fix for all receivers U have simple nite rider lights (----) on the display window.....box is far from dead...simple fix...use 2 hands...shut off receiver with rear switch...get loader and factory bin ready...with one hand, turn on receiver with rear switch, IMPORTANT...... IMMEDIATELY at first dash , click loader "download/write" button, with mouse using other hand...and upload the factory fix...its all about timing and being persistent...may take 30 attempts...then reload the latest fix correctly ... |
Bronze Member Username: LoikkuPost Number: 13 Registered: Dec-05 | i can't put my viewsat back , I make step by step but don't work What I can make now about this? |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1365 Registered: Jan-08 | Which Viewsat you have? |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1368 Registered: Jan-08 | loikku This setting is for Vs Ultra If not take the loader and factory bin for your box, whit same instuction. In your package box with receiver is furnish a cable RS-232 you must download factory bin with the cable from your computer . Go to: <[link removed]> download this 2 files: PVR Loader v11 - Firmware Updater ( Serial)you install this one on computer VS2000 ULTRA Factory Bin File - V132 for download with the loader in your receiver close rear switch on receiver open program take file v131 clic to download in receiver and a second after switch on the transfert take 5-10 mins you must see 0000 download the last bin with USB Good luck |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1369 Registered: Jan-08 | loikku you need to do it after, because if your box is dead, you have box with bad virus. Read it and do what is write for recover your box without problem. https://www.ecoustics.com/electronics/forum/home-video/466791.html Good luck |
Bronze Member Username: LoikkuPost Number: 14 Registered: Dec-05 | Thank's for all I didn't obtain nothing I have this Viewsat Pro for long time, I never used your serial port, Could be a problem? |
Bronze Member Username: LoikkuPost Number: 15 Registered: Dec-05 | Sorry, My Viewsat is Ultra |
Silver Member Username: DimwittPost Number: 522 Registered: Aug-06 | you need to use the null cable and loader2 to fix it. |
Bronze Member Username: LoikkuPost Number: 16 Registered: Dec-05 | I did , but nothing null cable is a black? |
Silver Member Username: DimwittPost Number: 523 Registered: Aug-06 | could be , i guess-- is it from a different receiver ? did it come with the vs ultra ? what you want to do is have loader2 ready with the ultra factory bin, turn on ultra with backswitch then hit pc to stb on loader2. if that doesnt work try pc to stb on loader2 then turn on the ulta with the backswitch. (try both methods several times before giving up) assuming you have the correct cable |
