he has dish 500 with dual lnb (stick together). which signal should I aim first.
which are the atenna setting /. ? or can I use the same setting as I currunt use for my sattlelite ?
i'm using regular dish 18" for 119 and added extra lnb for 110.
my question is can I use the same atenna setting as mine satellite to his dish 500 ?? or do i have to do something different ? we both have vs ultra help thanks
Ken, we have given you a lot of advice on this subject before,here is what you need to do go to www.dishpointer.com put your brothers address in there and select 199 and go.it will give you exact elevation and skew.you align 119 first.once you do this you will have to do antenna settings and scan
LNB power: on LNB Type is standart or OCS-DP choose for have strong signal LNB freq: 11250 22Khz: off TP freq: 12224 DiseQc 1.0: Port 1 or 2 choose same you insatall your switch Motor: off Legacy switch: if you have one choose the good one if not: none
