Username: Bvvenegas Post Number: 232 Registered: Apr-07
Saturday, March 29, 2008 - 05:45 GMT i put bin 259 in my pansat and it worked all last night but today it works and then freeaes and goes blank and the reciever losses the channel and a zero appears can someone tell me what to do
Username: Metallica Post Number: 483 Registered: Jan-08
Saturday, March 29, 2008 - 06:09 GMT Humberto..i think 259 is a bad bin..they changed it to the 260 bin now..go download the latest 260 bin it work.
Username: Drshahi Post Number: 28 Registered: Nov-07
Saturday, March 29, 2008 - 06:26 GMT I am having the same problem with 260 bin also.
Username: Dude123 Post Number: 2152 Registered: Jul-06
Saturday, March 29, 2008 - 06:52 GMT 259 was the one corrupted, 260 works like a charm for me, no problems so far.
Username: Heavygirl431 Post Number: 8 Registered: Aug-07
Saturday, March 29, 2008 - 18:33 GMT I am having the same problem too with 260
Username: Lklives Post Number: 14962 Registered: Jan-06
Saturday, March 29, 2008 - 19:36 GMT Start by a simple rear switch reboot.. If No changes, then start from scratch with a factory default/reset, factory bin, reinput settings, load latest fix and do new scans, lets keys auroroll and reboot again...always check cable and connections too Pansat is notorios for lousy problematic fixes..
Username: Heavygirl431 Post Number: 9 Registered: Aug-07
Saturday, March 29, 2008 - 19:43 GMT have did the rear switch reboot did not work, but will try other, thanks LK
Username: Tgyoung1 Illinois
U.s.a.
Post Number: 26 Registered: Jul-06
Saturday, March 29, 2008 - 19:49 GMT have pansat 2700 works great 260 but can't get cnn news or speed channels?
