Bronze Member Username: SarahkThunder Bay, Ontario Canada Post Number: 40 Registered: Jun-06 | Hi my dish is not working, like we put in the wrong bin accidently, it worked for a like 2 hours and then it went blank. It does not light up either. Please tell me if there is a way i can fix it. Its a FLU...converted into pansat. thanks |
Gold Member Username: Saqeeb9000Post Number: 2973 Registered: Oct-07 | ur rec is dead............. |
Bronze Member Username: SarahkThunder Bay, Ontario Canada Post Number: 41 Registered: Jun-06 | is there any way to fix it...? |
Gold Member Username: Saqeeb9000Post Number: 2974 Registered: Oct-07 | u need to gtaj ur rec .. its not simple like loading bin.. u need to get some equip, open up the rec and gtaj it.. just search how to gtaj a rec on google. |
Gold Member Username: Saqeeb9000Post Number: 2975 Registered: Oct-07 | and if u are planning to buy a new rec buy nfusion , neosat ipr 2000+ or sonicview 4000 rec... |
Bronze Member Username: SarahkThunder Bay, Ontario Canada Post Number: 42 Registered: Jun-06 | Hey...thanks for replying, what does "gtaj" mean? I searched it up on google, doesnt give me any results..plzz help thanks |
Gold Member Username: Saqeeb9000Post Number: 2976 Registered: Oct-07 | http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D270223528001&ih=017&categ ory=294%26%26 |
Gold Member Username: NydasPost Number: 9615 Registered: Jun-06 | You haven't said what dish you have what sats you were scanning and what BIN you installed using what loader. If details are given somebody might have a solution for you. |
Bronze Member Username: BorearBessemer, Al U.s.a. Post Number: 19 Registered: Jun-06 | wow you need to strap a brick too it and throw it as far into your nearest lake or river |
Gold Member Username: Saqeeb9000Post Number: 2979 Registered: Oct-07 | LK Unregistered guest Posted on Friday, September 09, 2005 - 11:17 am: -------------------------------------------------------------------------------- nope..I think U have an easy fix...but must do repeatedly until it works..The updater and factory 222 bin are are almost every Dss site.. Instructions fixing your Pansat2300A and 2500A. 1) Open Blacklist Stb Updater 1.3a 2) Browse original bin ( Factory 222 bin for 2500) Pansat 2500A or 2300A api BIN included 3) Connect from PC to REC with DB9 straight cable. 4) Keep your receiver off. DON NOT TURN THE RECEIVER ON FROM THE BACK SWICH. 5) Press Send button on BLACKLIST STB UPDATER 1.3a 5) Then turn your receiver on from the back swich within 5 secound. 6) Wait until download completed. DON NOT TOUCH ANYTHING UNTIL YOU SEE MESSAGE (Completed) 7) DO NOT LET THE RECEIVER TO RESTART BY IT SELF. 8) After you see message completed, Swich off back button on the back of the receiver right away. 9) Wait for 10 Second and turn your receiver on again. 10) Enjoy Your Tv Back. Regards Blacklist. Attached Files blacklist_jtagless_pansat_fix.zip (674.8 KB, 169 views) LK Unregistered guest Posted on Friday, September 09, 2005 - 11:22 am: -------------------------------------------------------------------------------- Pansat jtag software download -------------------------------------------------------------------------------- Software useless unless you have the right harware for it. This software will allow you to fix all knight rider, Dead, and Boot version update. Release Date on : 07.20.2005 [link removed] |
Bronze Member Username: BorearBessemer, Al U.s.a. Post Number: 20 Registered: Jun-06 | jtagging is manually clearing the file through a cable hooked too your printer port |
Gold Member Username: Saqeeb9000Post Number: 2980 Registered: Oct-07 | ok nalin is here.. he knows in and out of pansat.. so he will help you...he is master in pansat.. keep up good work nalin |
Bronze Member Username: SarahkThunder Bay, Ontario Canada Post Number: 43 Registered: Jun-06 | thanks for replying guys...umm...ok its fortec lifetime ultra, scanning echo3, and using blacklist updator v1.4...i am sorry cant tell what bin was put on it, my parents did that while i was out, so ill let you know as soon as i find out. The bin did work for like 2 hours where like all indian channels came (including starone and starplus) Thanks for helping me out!! |
Gold Member Username: NydasPost Number: 9625 Registered: Jun-06 | It appears that you have installed an original Pansat 2700 BIN on a converted receiver. Those BINs have a clone killer in it and that would do what you have got. You may have to jtag, but you could try a jtagless method and see if it will work. the instructions in the Rever to 2500 or boot60 subdirectory in one of the three kits that are posted. You will have to download the kit and unzip into a separate directory, and then force a b60 boot. Instead of th eusual instructions, you may have to do this. Get ready to write Boot file (not BIN file) with b60 boot selected. Then with receiver off, almost simultaneously you switch on and click on "write " It may work. Otherwise you are in for a jtag - jtag cable and software etc needed. The site to go for info [link removed] |
Bronze Member Username: SarahkThunder Bay, Ontario Canada Post Number: 44 Registered: Jun-06 | sorry...a little confused on where to get the Rever to 2500 or boot60 subdirectory...like where can i find the kits. And i kinda dont understand the website... |
Gold Member Username: NydasPost Number: 9630 Registered: Jun-06 | Sorry - I did not post the link to this public box. http://public.box.net/2500_full_kit In the b75 section in the full-kit when unzipped the directory is revert to 2500. Instuctions are there. In the PUFF section it is called b60 or boot 60 directory. Read the instructions. |
Silver Member Username: LuserPost Number: 166 Registered: Nov-07 | Try Sadas C/P of LK's C/P from BL. |
Bronze Member Username: SarahkThunder Bay, Ontario Canada Post Number: 45 Registered: Jun-06 | Thanks Nylin...i am just trying that... |
Bronze Member Username: SarahkThunder Bay, Ontario Canada Post Number: 46 Registered: Jun-06 | Nylin, the boot60 file did not work..its not letting me write it..and gives me errors...any other thing i can do bfr the jtag? |
Bronze Member Username: SarahkThunder Bay, Ontario Canada Post Number: 47 Registered: Jun-06 | Sada, i am kinda confused on your way to fix it, like does it work on FLU converted to pansat? and where can i get the file from. thanks |
Silver Member Username: LuserPost Number: 168 Registered: Nov-07 | These smaller receivers due to lack of memory just get stuck on stupid and need to be turned off in the back for a minute. Always try that first before anything else. |
Gold Member Username: Saqeeb9000Post Number: 2988 Registered: Oct-07 | i never owned a pansat/neither i did any jtaging my self..i just found some stuff that might give u some directions.. as i mentioned above its not easy as downloading a bin.. |
Gold Member Username: NydasPost Number: 9635 Registered: Jun-06 | As I stated before, there is a small chance that repeated trials using forced b60 load onto the receiver might work. There are two more kits available but they are of a similar nature to the ones I described earlier. They both work well if there is light but not likely to work if there is no light. Ultra boot repair kit.zip blacklist_jtagless_pansat_fix.zip There is no point in asking repeatedly for help. I have pointed to all the available tools without jtag. I have given the explanation why it occurred. If everything else fails, you have to get jtag cable and instructions. The URL given above by Sada is for a Pansat 3500. ebay usually has all different jtag cables advertised. You need the one for fortec ultra - the Pansat 2500 jtag cable might be OK, but you should now spend time reading about jtagging at: [link removed] Read in the fortec ultra, Pansat 2500 and Pansat clone sections. You will have to decide if you can justify the cost. |
