New member Username: Chift21Post Number: 9 Registered: Nov-07 | what is the advantages (if any) from changing b75 to Puff? |
Silver Member Username: MetallicaPost Number: 481 Registered: Jan-08 | what i know is the Puff have more memory than the b75...or maybe later the b75 file might stop coming out..so they only work on the Puff bin and the LZMA bin...if the b75 bin still come out too it might be late than the Puff and LZMA bin..that my 2cents |
New member Username: Chift21Post Number: 10 Registered: Nov-07 | have you swithced over yourself? |
Silver Member Username: MetallicaPost Number: 482 Registered: Jan-08 | No not yet..i have the 2500 converted to 2700 Flu like your too..but i don't use this box anymore just put it a side...now i use just the 3500SD and the Extreme.. if i were you i go ahead to convert it to Puff or Puff LZMA...it's easy just a few step you done.. |
Bronze Member Username: Chift21Post Number: 11 Registered: Nov-07 | thanks for the input |
Gold Member Username: NydasPost Number: 9648 Registered: Jun-06 | PUFF_LZMA recommended https://www.ecoustics.com/electronics/forum/home-video/465397.html |
