ok to convert to puff what is the steps for a 2500 to 2700 converted already with the B75 Conversion in other words the old conversion is already installed on mine so do i convert it back to 2500 first then reconvert back to puff?
alton vann penny. If you want to keep your ch.list and your settings. save it using GtRomloader 27.02 connect STB with usual cable ,turn On your STB open 27.02 loader and click on Upload, save your ch.list ,name it (2500 ch.list or something like that) after the conversion ,when stb said ON, use again loader 27.02 and chose your ch.list and click download ,wait untill stb swhow CH# .turn Off stb, connect stb to tv, press 8282 set default keys and wait for picture to comes.
Why so many steps, just use BLloader updater 1.4 and use Jvvh 253 Canam converter .bin file. ( do it as you normally download the bin ) turn ON your stb,etc,,,etc, STB will reboot wait untill you see PUFF PUFF then with the same loader 1.4 chose Jvvh 260_Nkk_PUFF bin aand when the first P appears click "write bin" then wait until STB shows ON .
Do not convert to Lzma as PUFF has been chosen as the compression of choise to develops things with .
