Puff 254T down
Username: Snuffles07
Post Number: 47
This is what it says in my system information:
CISafe
Puff:75-254T_EUbX
Boot ver:75
04.Mar.2008
Can anyone tell me how to update to a working bin? My receiver is a Vortex Pro 7700
Username: Nydas
Post Number: 9514
All of DN and BEV are down.
Wait for new BIN 259 - hopefully tomorrow.
Post Number: 48
O.K. thanks, but how do I change from regular PUFF to LZMA PUFF?
Username: Nydas
Post Number: 9516
Sirius Black:
https://www.ecoustics.com/electronics/forum/home-video/465397.html
Post Number: 53
Nalin, you have too many things to download from your page. I wanna know what to download if I have this:
CISafe
Puff:75-254T_EUbX
Boot ver:75
04.Mar.2008
in my box and I wanna convert to LZMA PUFF.
Username: Nydas
Post Number: 9603
If you want to convert to LZMA_PUFF (same as PUFF_LZMA), download the
Full_Kit_PUFF_LZMA_260B.zip from that directory
Unzip in a separate directory in your computer and follow the instructions in that folder.
Post Number: 54
O.K., are you sure you want me to use that for my Vortex Pro 7700 given the specifications I posted earlier?
Post Number: 55
Also, if I have PUFF do I have to go back and boot 60 before I install LZMA_PUFF?
Username: Nydas
Post Number: 9612
Your original receiver name is meaningless now that you are converted.
You have b75, and just follow the instructions from section C onwards.
Username: Boho
Hello Nalin,
The last working bin file I had was 'Jvvh_254_Nkk Converted", which I gather needs to be updated. What is the next bin file I need to load on to my Fortec Lifetime Ultra.? If you have a link that would be great.
Thanks in advance
Username: Nydas
Post Number: 9636
You should check whether you have b75 or PUFF or PUFF_LMZA boot.
when you turn on, if it shows b-7-5 scrolling it is b75, if P-U-F-F scrolling it is PUFF and if P-U-F-F. scrolling with a halt on last F. and period there (decimal point) it is LZMA. You can go into system info and see the name - it will have 75 for b75 or PUFF for PUFF or LMZA somewhere.
Once you have decided what you have you can upgrade to 260 BIN. You can stay with the BIN for the BOOT you have or go up to PUFF_LMZA level. The choice is yours. Download the appropriate file and FOLLOW THE INSTRUCTIONS. THERE ARE NO SHORT CUTS.
Either b75 or PUFF or PUFF_ LMZA
http://public.box.net/2500_full_kit
