How can i deleted channels in cw 600s
Username: Anairis07
Post Number: 24
how can i deleted channels on my cw 600s because i have duplicated channels
Username: Jwl1
Post Number: 253
You could delete all channels and start over. It would be the easiest way, I believe. Go into the menu where the default is and select delete all channels.
Username: Brucester
Post Number: 1389
or you can do 1 at a time long way but you get the ch you want this way hit ok on remote then f3 pip at the botom of the remot it is eazy to do hope this helps
