}I have done a factory defoult, Install and re-install the factory bin. blind scan on 119 and 110 But I still have some scramble channel why?... I have very strong signal,most channels work but I'm missing many PPV Only 502 505 and I think 509 under sat 119 work, The rest under 110 are scramble any reason? HELP!!!!!
Sal--perhaps, it is the antenna setting. If it's not on the strongest one, it won't pick all the channels up when you scan. Therefore, check your settings.
If that isn't the case, then you should be able to fix the problem by just doing a reset--turning the switch off and then on from the back.
When you did all that you mentioned, I assume you then activated F1? I would assume so, since it appears not all of your channels are scrambled.
