Silver Member Username: Espn3Post Number: 258 Registered: Aug-06 | When are you going to post the new jvvh_260.bin for the FLUs converted to Pansat 2700 ? thanks. | |
Gold Member Username: NydasPost Number: 9540 Registered: Jun-06 | Conversion BINs 260 - b75, PUFF and PUFF_LZMA are all posted at: http://public.box.net/2500_full_kit |
Silver Member Username: Espn3Post Number: 261 Registered: Aug-06 | Nalin, I have the FLU converted to Pansat 2700 and worked very good with the jvvh_*** bins in the past. Today I loaded the 260_p122654_AIO.bin and works very good. Why should I convert to PUUF or PUFF_LZMA ? thanks. | |
Gold Member Username: NydasPost Number: 9559 Registered: Jun-06 | If you are not converted and using the b75 BOOT is OK, do continue. I was not recommending conversion, but having done the PUFF conversion and then the LZMA conversion, I found that the PUFF conversion was a little tricky, but the PUFF_LZMA conversion from PUFF is extremely straight forward. |
Silver Member Username: Espn3Post Number: 262 Registered: Aug-06 | Thanks Nalin. From what I understand I can stay with this b75 conversion and look for jvvh or p122654 type of bins. Have a great day. |
Gold Member Username: NydasPost Number: 9561 Registered: Jun-06 | I am sure there will be more BINs out for the b75 conversions. | |
Silver Member Username: Bill038Post Number: 606 Registered: Sep-06 | If you listen to nalin, the wicked witch of the north, she will kill your box, send you to hacked sites and turn you in to DN. Check her post counts, that is really the number of boxes she has killed. Do you know when she is going to kill a box.......................The next time she posts and someone takes her advice. Stay afrom her advice, she is here to send you to hacked sites and kill your fta box. |
Gold Member Username: NydasPost Number: 9568 Registered: Jun-06 | I tried out th eb75 BIN 260_p122654_AIO and found that it destroys the settings and you have to set it up completely or load the channels from Channel Master. |
Silver Member Username: Bill038Post Number: 615 Registered: Sep-06 | If you listen to nalin, the wicked witch of the north, she will kill your box, send you to hacked sites and turn you in to DN. Check her post counts, that is really the number of boxes she has killed. Do you know when she is going to kill a box.......................The next time she posts and someone takes her advice. Stay afrom her advice, she is here to send you to hacked sites and kill your fta box. |
Gold Member Username: NydasPost Number: 9571 Registered: Jun-06 | Could somebody please call pest control? | |
Silver Member Username: Bill038Post Number: 617 Registered: Sep-06 | If you listen to nalin, the wicked witch of the north, she will kill your box, send you to hacked sites and turn you in to DN. Check her post counts, that is really the number of boxes she has killed. Do you know when she is going to kill a box.......................The next time she posts and someone takes her advice. Stay afrom her advice, she is here to send you to hacked sites and kill your fta box. |
Gold Member Username: NydasPost Number: 9579 Registered: Jun-06 | Could somebody please call pest control?
Silver Member Username: North_of_ontarioPost Number: 594 Registered: Sep-07 | ||
Gold Member Username: NydasPost Number: 9597 Registered: Jun-06 | Ryerson: You were suspended and now posting as Maple leaf. You won't be there too long under that name. |
Silver Member Username: North_of_ontarioPost Number: 597 Registered: Sep-07 | ||
Bronze Member Username: Flu_guyPost Number: 79 Registered: Aug-07 | Hi Nalin I just loaded the 260_p122654_AIO.bin from your box into my FLU and it works perfectly, I didn't have to reset my settings or rescan either, never do, in fact. As I said before, I really think it depends on the number of channels and so on one has loaded, I only have 119 with about 300 chans in memory you see. Anyway, thanks for posting the files and keeping track of whats going on Htiek |
Bronze Member Username: Rockman169Canada Post Number: 22 Registered: Nov-06 | i have converted to puff now i would like to convert to puff lzma so do i start at the d section on the instruction in your full kit thanks | |
Gold Member Username: NydasPost Number: 9611 Registered: Jun-06 | Just follow the instructions. You start at section D of the instructions. Don't panic and work all the way through. | |
Bronze Member Username: Rockman169Canada Post Number: 23 Registered: Nov-06 | thanks nalin your the best | |
Silver Member Username: Snw7619Bahamas Post Number: 202 Registered: Oct-06 | nalin im looking to get new receiver what should i get $100-$200 range i have now pansat 2500>>2700 and want something with usb loading. thanks |
Platinum Member Username: LklivesPost Number: 14955 Registered: Jan-06 | Island ..u are a greenhorn , a complete newbie...so heres some good advice... U may as well call Dishnetwork , instead of asking Nalin Nyda...cause Nalin is a DN official here in disguise..monitoring this site and FTA news , and all the members here.. heres the best USB ready...and all are very good with great software support conaxsat mini captiveworks 700 or 800 (PVR also included) sonicview 4000 viewsat ultra |
Gold Member Username: NydasPost Number: 9638 Registered: Jun-06 | Island Tv: Normally I would have said $160 for a Sonicview 4000. However Nagreqavision 3 is just coming on stream and by mid-may we would know if a big darkness is going to spread all over the FTA world as it did in 2006. If you can wait for a while it would be good. By the way, the 2500 to 2700 converted receiver with LZMA boot/BIN works extremely well. I have both - a SV4000 and a converted receiver and I find no difference with the current BIN except that the autoroll take a little longer (2-3 minutes) |
