Ehren
Username: Th3pwn3r
Post Number:...
Post Number: 7613
Hey man, I got an extra Warcraft 3 Reign Of Chaos and Frozen throne key set. If you wanna jump back into WC3 let me know and I'll hook you up. Just send me a pm with your E-mail and will discuss the details.
Username: Pitbullguy
The Chicago area
Post Number: 3027
funny you should mention WC... i just relapsed on ROC a couple weeks ago.
I've always wanted to try dota on FT but never got around to buying it for some reason. What do you mean when you say you have a frozen throne "key set"?
Username: Th3pwn3r
Post Number:...
Post Number: 7615
I was talking about CD keys.
The Chicago area
Post Number: 3028
well yeah i figured you meant you had the keys, but i don't even have the Frozen Throne expansion, so the key wouldn't do me much good.
Username: Th3pwn3r
Post Number:...
Post Number: 7616
Damn, you're slow lol. I'll send you the disc. You install it and then send it back haha. You no longer need the disc to play. You may even be able to DL Frozen Throne and then I'll just hook it up with a key.
The Chicago area
Post Number: 3031
"Damn, you're slow lol."
what? what do you mean by that? I run all the time and i'm a pretty good sprinter so i have no clue what you're getting at here.
