Lost All Channels on VS Ultra After Blind Scan
Username: Crazydoo67
Hi,
I lost my DN channels last night so I thought I might try a blind scan 2 get them back since there are no new files.
After the blind scan, lost all the BEV channels. Now have no channels. I did an autoscan. Put back the Mar. 11/08 file and still no channels. Let it autoroll overnight. No channels still. I've shut the receiver on and off. What else can I do? I have Nimiq 1,3 and Echostar 3 selected as my satellites.
Can some1 help? I have no tv channels. It ain't pretty.
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 1313
Fou
Go on dsstesterDOTcom
on left side select "viewsat files"
and download this file
Download PFTAUSW-080311U.zip (1174.14KB)
unzip it
If that dont work reply
Username: Mucho
Post Number: 142
Hey friend try this.
A) Factory Settings
B) User Setup
C) Blind Scan EchoStar 3
D) Set default Keys (wait) if they don't roll
go here for the updated Keys.
[link removed]
Hi Plymouth, I
downloaded the pftausw-080311u.zip..already had it actually and i reloaded it but still no channels..
I had BEV channels b4 I did the blindscan..just no DN channels. I should have left it as is cuz some channels are better than none..
Whitehawk I've tried what you suggested as well. No signal on DN. I'm not sure what else I can do.
Username: Plymouth
Post Number: 1315
try it:
All viewsat box
Go to Code menu
Select Nagra and on Dish 01 06 00 Dish 00 01 00 dish 01 01 00
Delete this 3 provider one by one with F3 on remote
no need to delete keys
switch off 10 secs on back panel
and load last bin for your box (from dsstester)
turn autoroll on
Keep on
Bin and autoroll regenerete keys
Resolve problem with lost channel , autoroll, freeze and search signal
Thats erase bad data in the box
For box who lost channel and sat setup
ENJOY TV
TESTED and work fine
New issue for problem on Viewsat
Thanks
Do a auto scan on your sat after for recover all channel
Dont do a factory reset and factory bin
No need it
Reply if it work
Please
