Viewsat Xtreme not working
Username: Teehee123
Post Number: 11
I have a viewsat xtreme which suddenly stopped working a couple of hours ago...the signal and quality both keep fluctuating and I have tried changing the antenna setup settings but nothing has any effect on it...except when i turn LNB Power on ...then the signal is constant and the quality is 0
I have tried Plymouth's advice of Reloading Factory Bin, and then the latest bin file but nothing has worked
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 1251
teetee
do you have switch on your system?
fluctuation is like water in switch or bad connection
Username: Teehee123
Post Number: 12
im sorry i dont get what you mean by switch on my system
Username: Plymouth
Post Number: 1252
How many dish and LNB you have?
Username: Teehee123
Post Number: 13
it has snowed today where i live and there have been really strong winds, perhaps the dish moved...unfortunately my satellite is positioned extremely high on my roof and its hard to access
Username: Teehee123
Post Number: 14
i have echostar 3 and 7 and 1 LNB i believe
Username: Plymouth
Post Number: 1253
Check your dish before do anything.
If you have a friend with a dish
try your receiver on his dish.
Sorry
Username: Teehee123
Post Number: 15
okay thanks a lot i'll try something =)
Username: Mane
Post Number: 28
first of all check your dish it covered with snow if it is cover clean the snow from the dish
Username: Teehee123
Post Number: 16
that might be the problem...i just wont be able to reach the dish anytime soon...not until the weather gets a bit warmer at least
Username: The_coders
Post Number: 760
go to walmart and buy a super-soaker and fill it with windshield washer fluid or de-icer, and fire away.
Username: Teehee123
Post Number: 17
okay my dish suddenly started working again lol ...maybe the snow melted or something..thanks everyone for ur help
