Username: Top2000dogg Post Number: 78 Registered: Jul-07
Monday, March 24, 2008 - 17:29 GMT I have a pansat 2500 clone and have converted it to a 2700 and have also downloaded the bin Jvvh254nkk and I still couldn't get anything also have downloaded the bin cs259T b-75 lightning serial and still nothing I don't get the signal, I really need your help?! I can't my signal strength to go up?
Username: Rtap FL
Post Number: 2065 Registered: Jan-07
Monday, March 24, 2008 - 17:34 GMT check your settings in antenna setup.
Username: Top2000dogg Post Number: 79 Registered: Jul-07
Monday, March 24, 2008 - 18:01 GMT how do I do that?
Username: Rtap FL
Post Number: 2067 Registered: Jan-07
Monday, March 24, 2008 - 18:02 GMT go into menu and select antenna setup
Username: Top2000dogg Post Number: 80 Registered: Jul-07
Monday, March 24, 2008 - 18:20 GMT and then? thanx for the help
Username: Rtap FL
Post Number: 2069 Registered: Jan-07
Monday, March 24, 2008 - 18:34 GMT go into what ever sats you plan to use and set the settings correctly.if you don't know how just post here the settings that are there now so we can help
Username: Kirankumar NO Bashing
Post Number: 2246 Registered: Oct-07
Monday, March 24, 2008 - 18:38 GMT fill this out so someone can help you STB (Brand/Model) -->: Dish (Size? Motor? # of LNB's) -->: LNB Type -->: Switch used? (Type?, Brand?, Inside/Outside? -->: Your Antenna Settings by Sat # Fill in all Settings and REPEAT for each sat your using! Sat (Name/#) -->: LNB Power -->: Lnb Type -->: Lnb Freq (Hi/Lo)-->: 22khz -->: TP Freq. -->: Search Opt. -->: Diseqc -->: Motor -->: Legacy SW -->:
Username: Rtap FL
Post Number: 2072 Registered: Jan-07
Monday, March 24, 2008 - 19:00 GMT good post african
Username: Kayoss Post Number: 24 Registered: Feb-08
Monday, March 24, 2008 - 20:58 GMT African, I think you should also ask what medication they are on just in case.
Username: Top2000dogg Post Number: 81 Registered: Jul-07
Tuesday, March 25, 2008 - 06:26 GMT Thanx African and Rtap and sorry for the delay! My Box is a Megasat YT6688 Sat 1 - T-7/ku LNB Type - Standard LNB Local-Freq - 10750 22khz - off Diseqc - off Legacy SW - none Skew - -45 TP - [1] 11950 V 8.684 Positioner Setting - Disable Satellite Scan - all Sat 2 - Echo 7/ku LNB type - Dish-pro LNB Local-Freq - 11250 22khz - off Diseqc - #1 Legacy SW - none Skew - -45 TP - [1] 12225 V 20.000 Positioner Setting - Disable Satellite Scan - all Sat 3 - Echo 8.10/ku LNB type - Dish-pro LNB Local-Freq - 11250 22khz - off Diseqc - #2 Legacy SW - none Skew - -45 TP - [1] 12224 V 20.000 Positioner Setting - Disable Satellite Scan - all
Username: Pathfinder191 Post Number: 380 Registered: Mar-06
Tuesday, March 25, 2008 - 10:14 GMT In your sat 1, change LNB frequency to 11250. Your Diseqc currently off, put the correct number 1, 2, 3 or 4 whichever is applicable. Sat 2 & 3, LNB type is Dish-pro, make sure you have Dish-pro or standard LNB. Make sure you change them to currect LNB type also check your Diseqc numbers that you have to check physically. Otherwise rest of your settings look ok. Good luck.
Username: Pulpfiktion Post Number: 51 Registered: Mar-08
Tuesday, March 25, 2008 - 16:09 GMT
Username: Pulpfiktion Post Number: 52 Registered: Mar-08
Post Number: 2250 Registered: Oct-07
Tuesday, March 25, 2008 - 16:50 GMT it seems like you have 1 dish,in that case your settings are good for 119 and 110.check your cables,and connectors,if they are ok then you might have to align your dish slightly,it might have moved a bit.go to www.dishpointer.com for exact alignment post results please
Username: Rtap FL
Post Number: 2073 Registered: Jan-07
Tuesday, March 25, 2008 - 17:15 GMT make sure you have dish-pro or standard dish pro lNB
Username: Top2000dogg Post Number: 82 Registered: Jul-07
Tuesday, March 25, 2008 - 18:07 GMT what do you mean dish-pro or standard? and whats the difference?
Username: Rtap FL
Post Number: 2076 Registered: Jan-07
Tuesday, March 25, 2008 - 18:22 GMT look at the picture above.that is a dish pro dual lnb.if you have this lnb then your setting should be dish pro and have the diseq setting to off
Username: Rtap FL
Post Number: 2077 Registered: Jan-07
Tuesday, March 25, 2008 - 18:26 GMT remember the dual lnb has a built in switch and will not work if you add a diseq switch to the mix
Post Number: 2251 Registered: Oct-07
Tuesday, March 25, 2008 - 18:33 GMT if you look at your lnb and it has a dp logo then it means it is a dishpro lnb and it has a built in switch like RTAP is saying
Username: Top2000dogg Post Number: 83 Registered: Jul-07
Tuesday, March 25, 2008 - 19:51 GMT it looks like a dish-pro, so all the satellites should be dish-pro? and diseq should be off right!
Username: Top2000dogg Post Number: 84 Registered: Jul-07
Tuesday, March 25, 2008 - 20:06 GMT does the dishpointer.com really work?
Username: Rtap FL
Post Number: 2083 Registered: Jan-07
Wednesday, March 26, 2008 - 18:21 GMT http://satcalculator.freehostia.com/
Username: Bill038 Post Number: 595 Registered: Sep-06
Wednesday, March 26, 2008 - 18:39 GMT Careful RTAP, someone will c/p you and get you banned again.
Username: Top2000dogg Post Number: 85 Registered: Jul-07
Wednesday, March 26, 2008 - 18:52 GMT thanx rtap!
Username: Rtap FL
Post Number: 2084 Registered: Jan-07
Wednesday, March 26, 2008 - 18:54 GMT your welcome sean.lol bill you been missing in action.how have you been
Username: Bill038 Post Number: 596 Registered: Sep-06
Wednesday, March 26, 2008 - 19:02 GMT Around not at home now out checking some things and some people. In Canada right now looking up some people. Should be all done and home by the end of May
Username: Rtap FL
Post Number: 2085 Registered: Jan-07
Wednesday, March 26, 2008 - 19:20 GMT nice vacation.see you at crazy in may peace.
Username: Pulpfiktion Post Number: 66 Registered: Mar-08
Wednesday, March 26, 2008 - 20:06 GMT Vickers and RTAP can horse around like CRAZY at Crazy cafe.
Username: Rtap FL
Post Number: 2087 Registered: Jan-07
Wednesday, March 26, 2008 - 20:09 GMT hi nalin
Username: Pulpfiktion Post Number: 71 Registered: Mar-08
Wednesday, March 26, 2008 - 20:27 GMT RTAP SAYING Hi to Nasty Nalin aka Postergirl1 RTAP - U can go higher than that - can't U?
