Username: Teehee123 Post Number: 11 Registered: Jan-08
Tuesday, March 25, 2008 - 23:37 GMT I have a viewsat xtreme which suddenly stopped working a couple of hours ago...the signal and quality both keep fluctuating and I have tried changing the antenna setup settings but nothing has any effect on it...except when i turn LNB Power on ...then the signal is constant and the quality is 0 I have tried Plymouth's advice of Reloading Factory Bin, and then the latest bin file but nothing has worked
Username: Plymouth Quebec city,
Quebec
Post Number: 1251 Registered: Jan-08
Tuesday, March 25, 2008 - 23:47 GMT teetee do you have switch on your system? fluctuation is like water in switch or bad connection
Username: Teehee123 Post Number: 12 Registered: Jan-08
Tuesday, March 25, 2008 - 23:51 GMT im sorry i dont get what you mean by switch on my system
Quebec
Post Number: 1252 Registered: Jan-08
Tuesday, March 25, 2008 - 23:54 GMT How many dish and LNB you have?
Username: Teehee123 Post Number: 13 Registered: Jan-08
Tuesday, March 25, 2008 - 23:55 GMT it has snowed today where i live and there have been really strong winds, perhaps the dish moved...unfortunately my satellite is positioned extremely high on my roof and its hard to access
Username: Teehee123 Post Number: 14 Registered: Jan-08
Tuesday, March 25, 2008 - 23:57 GMT i have echostar 3 and 7 and 1 LNB i believe
Quebec
Post Number: 1253 Registered: Jan-08
Wednesday, March 26, 2008 - 00:00 GMT Check your dish before do anything. If you have a friend with a dish try your receiver on his dish. Sorry
Username: Teehee123 Post Number: 15 Registered: Jan-08
Wednesday, March 26, 2008 - 00:01 GMT okay thanks a lot i'll try something =)
Username: Mane Post Number: 28 Registered: Sep-06
Wednesday, March 26, 2008 - 00:03 GMT first of all check your dish it covered with snow if it is cover clean the snow from the dish
Username: Teehee123 Post Number: 16 Registered: Jan-08
Wednesday, March 26, 2008 - 00:07 GMT that might be the problem...i just wont be able to reach the dish anytime soon...not until the weather gets a bit warmer at least
Username: The_coders Post Number: 760 Registered: Jan-08
Wednesday, March 26, 2008 - 00:12 GMT go to walmart and buy a super-soaker and fill it with windshield washer fluid or de-icer, and fire away.
Username: Teehee123 Post Number: 17 Registered: Jan-08
Wednesday, March 26, 2008 - 02:42 GMT okay my dish suddenly started working again lol ...maybe the snow melted or something..thanks everyone for ur help
