Fortec to PUFF no signal
Username: Rekha
Post Number: 13
I have Fortec converted to PUFF. No quality signal since 4pm. I have 258Puff bin. Any suggestions
Username: Nydas
Post Number: 9453
rekha: I just checked a converted 2500 with a 258 PUFF BIN on DN channels and it seems OK.
Which sat are you scanning?
Username: Rekha
Post Number: 14
echo 3 and echo 7. It was working fine till 4pm. Then quality of signal disappeared.
Username: Nydas
Post Number: 9455
The DN channels are working fine even with PUFF_254.
Reload the BIN - try PUFF_254 of Chancy if 258 not working.
Username: Rekha
Post Number: 16
THANKS NALIN. I will try 254 puff
Username: Rekha
Post Number: 17
Nalin: Still no signal. Nothing is changed since 4pm. All the settings are same. It is snowing a bit but not as bad as JAN , Feb.
Username: Nydas
Post Number: 9457
I really have no other suggestion. I just tested and everything is fine on PUFF_254 BIN on DN channels.
Username: Rekha
Post Number: 18
Nalin: I went out to check the dishes. They were covered with snow. It is kind of freezing rain over here. I cleaned it up and everything is working. I should have checked it first.
Thank you again.
