Bronze Member Username: TopyPost Number: 25 Registered: Jan-07 | VS Ultra I scan one by one both dishes, but can't switch screen with sat button from remote, receiver detect only one dish at a time, case 1= when I am watching 148 & wants to change sat from remote I can't see 110 in my sat list, so what I found I have to choose programe from f2 list and select any channel which is under 110 and enter, screen shows nothing, no signal on screen, when I turn receiver off & back on from remote 110 backs up immediatly & now I can see all channels with 110, if I wants to see 148 I can press sat I can choose 1.2 echo & watch 148. Case 2= now if I wanna see 110 again, pressing sat button, there is no 110 in list & I have to go procedure 1 again ,,, damn frustration,, By the way when I scan channels in the begining I scaned one by one, cuz both setallite was'nt recognised by receiver at a time.. I changed 4 diseq switch all r acting the same,,, Please give me all possible answer in detail,,,, what I am missing,,, is it software problem ? is it only VS problem ? is it diseq switch problem ? help me |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1316 Registered: Jan-08 | try it: All viewsat box Go to Code menu Select Nagra and on Dish 01 06 00 Dish 00 01 00 dish 01 01 00 Delete this 3 provider one by one with F3 on remote no need to delete keys switch off 10 secs on back panel and load last bin for your box( from dsstesterDOTcom) turn autoroll on Keep on Bin and autoroll regenerete keys Resolve problem with lost channel , autoroll, freeze and search signal Thats erase bad data in the box For box who lost channel and sat setup ENJOY TV TESTED and work fine New issue for problem on Viewsat Thanks Do a auto scan on your sat after for recover all channel Dont do a factory reset and factory bin No need it Reply if it work Please |
Bronze Member Username: TopyPost Number: 26 Registered: Jan-07 | Thanks for reply, but this solution is not belong to my problem, as u said " Resolve problem with lost channel , autoroll, freeze and search signal " none of them is connected with my problem, thanks anyway |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1317 Registered: Jan-08 | Yes RK i read your problem before, Try it |
Bronze Member Username: TopyPost Number: 27 Registered: Jan-07 | I took the day off for this sshheeet,, I am passionate to resolve this now,,, I will try everything if make sense,,, ok I am going to try now ,,,, stay tuned |
Bronze Member Username: TopyPost Number: 28 Registered: Jan-07 | now nothing is happening, same old sheeeet, nothing changed at all,,, must be something else with software or switch or someting else |
Bronze Member Username: TopyPost Number: 29 Registered: Jan-07 | I called a dish installer, lol He was just dump, he couldn't figure out the answer, anyway if someone knows the answer reply,, thread is open for every "master mind". |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1318 Registered: Jan-08 | Try a hard reboot and download factory bin to : viewsatusa.com/support load this before last bin VS2000 ULTRA Factory Bin File - V0132 Good luck |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1319 Registered: Jan-08 | Did you try to delete provider like i say? |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1320 Registered: Jan-08 | See why that work just to read it: https://www.ecoustics.com/electronics/forum/home-video/463188.html And this too: https://www.ecoustics.com/electronics/forum/home-video/462712.html |
Bronze Member Username: TopyPost Number: 30 Registered: Jan-07 | No man its not working, I put it back on my previous position, |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1321 Registered: Jan-08 | Do what you went |
Gold Member Username: KirankumarNO Bashing Post Number: 2257 Registered: Oct-07 | do a factory reset.then download latest factory file.then load latest bin. now scan 110 first and then scan 119 post results |
Bronze Member Username: TopyPost Number: 31 Registered: Jan-07 | Problem is not missing channel, I can not switch sat from one to another, please read |
