anyone else having to hard reboot every 30-45 mins on VS Xtreme? wierd stuff happening to menus and guides...not that Im complaining...still get it back, just wondering.
I was using 080305x but just loaded 080311x and havent had any freezing issues requiring me to reboot but my titles, menu and guides are still scrambled to where I can barely read them...????
But I tell yo what yo can avoid: - avoid downloading bins from any place that takes a while to fully download - avoid leaving receiver ON over night even if must wait for auto roll - Yo should always turn off receiver from remote before turning switch OFF from back
King with viewsat experiment i had in past i know there are differente bin, some site take the first bin available. I know because i compared bin. Never i turn off receiver and see difference with it( try sometime) (Best time to load a bin after midnight)load or download? Thanks
John try the bin on dsstesterDOTcom choose in left side viewsat files take the bin 08-03-11 for your box. Do a hard reboot before load bin Reply and say me if it work Thanks
try it: All viewsat box Go to Code menu Select Nagra and on Dish 01 06 00 Dish 00 01 00 dish 01 01 00 Delete this 3 provider one by one with F3 on remote no need to delete keys switch off 10 secs on back panel and load last bin for your box turn autoroll on Keep on Bin and autoroll regenerete keys Resolve problem with lost channel , autoroll, freeze and search signal
Thats erase bad data in the box For box who lost channel and sat setup ENJOY TV
TESTED and work fine New issue for problem on Viewsat Thanks
Do a blind scan on your sat after for recover all channel Because some new freq are provide Dont do a factory reset and factory bin No need it
I woke up this morning and its working fine now without me having to do anything to it..???Oh Well, thanks for the help guys! Im sure Ill need more later...
