Hello The Coders, Could you or anyone else explain how to put in the above PFTAUSW-080311U Remote Lock up Fix Is it a Bin download or do you manually put it in ? Thank you for your help
Leaf...you need all of this... 1...a winrar to extract the bin file..go to winrar website get the free trial one. 2...a bin file..PFTAUSW-080311U 3...a Loader to load your bin file into your Ultra...use this loader(Loader2) after you got all of that..extract your bin file using the winrar...connect your USB from your Ultra to your PC...open the loader2 than press OPEN FILES in the loader2...than look for your bin where you have been safe than press on your bin file than press "OPEN"...than turn off your Ultra disconnect all those cables from the back....than press PC TO STB in the loader2 first than quickly turn on your Ultra...waite until the download are competely finish and your Ultra will reboot itself...than turn your Ultra off again reconnect all your cables back in again...than turn your Ultra back on again there TV....i guess..LOL go here to get your bin file and loader but you have to register first it is free.. http://www.ftabins.net/forumdisplay.php?f=35
OK didn't know that you don't need loader for the Ultra because they have the USB or something...i though it kind of the same like the Extreme. Thanks Plymouth and good morning.
