Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1205 Registered: Jan-08 | By Plymouth I found that because the frquency assigned by the bin is not the same like blind scan. we just to choose this channel on both one after the other and that come automatically delete one of two. because we have some post on it. It's not really a problem autoscan give me 133 channel blind scan give me 351 channel It's better to blind scan Now solution for it: Note your sat info and go in channel scan and delete sat in bottom, exit and return in antenna setup enter info you had note and exit and save and blind scan now you have all channel without double thats all Thanks |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1206 Registered: Jan-08 | If you need more info just to ask and tomorrow , i give you answer Thanks I go to sleep Goon night everybody |
Silver Member Username: LuserPost Number: 148 Registered: Nov-07 | If you look at the tp for each ch and one is V and one is H then likely you have DP lnb's and your getting regular and bandstacked. If this is true and you want the best possible scan/EPG do this. Go to lyngsat dot com get freq for sat tps then in channel scan menu check each manualy but for each horizonal subtract the # of the TP from 25600 and change it to vertical. Note: Lyngsat lists tps as L or R as opposed to H and V. Deal with it! |
Silver Member Username: LuserPost Number: 149 Registered: Nov-07 | P.S Make sure your type lnb setting is OCS-DP if your lnb has big black DP logo on the back. If it doesn't disregard previous post. |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1207 Registered: Jan-08 | Semore i dont see the reason for this reply, i know how change info on TP, no need to change nothing all channel is there. Explaine it please. If that not work, thats because the bin is not good. I have universal Invacom LNB it dont work on OCS-DP Thanks |
Bronze Member Username: Chip_laPost Number: 48 Registered: Oct-07 | I am still not getting plyby and ten I tried tp scan and then I tried adding a user channel and eeven though it comes up with plenty of signal no picture anyone have a solution. echo7 119 vs plat thanks chip |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 2635 Registered: Oct-06 | Plymouth What yo don't know is providers got 2 streams side by side from 2 satellites along with the 2 freq spectrums Lately I noticed the hide and seek frequency game Nagra also added frequency conditional access change as new keys roll in There is a lot more going on than yo and I can observe including unrepeated trial and errors many of them don't make too much sense at the moment which made me believe they are saving it to a later time |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1213 Registered: Jan-08 | KING I dont have this problem since, i delete provider the first time. The new solution for provider is not insert 01 06 00 in bin. Bad bin is on different sites. I see like you 2 freq for one channel both one on two is delete by itself. Warning it seem bin is not good on all site. King say if you went where you download your bin? Thanks |
Gold Member Username: RtapFL Post Number: 2068 Registered: Jan-07 | its normal to duplicate channels when you perform a blind scan on any receiver.a couple of things you can do to minimize this problem. 1- if using a switch bypass switch and run cable directly to dish and scan. 2 - make a channel list and save. |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1214 Registered: Jan-08 | Rtap you understand nothing on what we talk. Please stay away. This comment is useful has anything. And you dont know our setup. I give clearly the solution on this first post. Thanks |
Gold Member Username: RtapFL Post Number: 2071 Registered: Jan-07 | LMAO plymouth now it seems you try to control all threads you post in.i was just trying to help this person as you were doing.i've been doing this longer than you have so step off.and the way you write confuses the hell out of anyone.lol |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1216 Registered: Jan-08 | RTAP dont be worry. Read that it's clearly explained: autoscan give me 133 channel blind scan give me 351 channel It's better to blind scan Now solution for it: Note your sat info and go in channel scan and delete sat in bottom, exit and return in antenna setup enter info you had note and exit and save and blind scan now you have all channel without double thats all Thanks |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 2637 Registered: Oct-06 | I tried all 3 bins Dsstester, totalfta, ftahq they are all indenticall the same all made from one source Sometimes older bins work well too Like I said above try loading when there is no high traffic Plymouth yo need to take it easy on other members RTAP was right about blind scan It's important to hear other members impact Yo are mixing few things about provider 0106 Lately DN has been quite with recent ECMs for unkown reasons Yo don't have freeze problems since yo deleted 0106 I also don't have feeze problems without deleting anything I think they are 2 isolated issues I'm still not sure what yo mean by this? "I see like you 2 freq for one channel both one on two is delete by itself. " Can yo explain this one more time please? Are yo talking about when yo do blind scan? I don't get the part "delete by itself"??? Yo may have come across something I haven't!!! |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1217 Registered: Jan-08 | No King it's not isolated, i help many people here and on a another site many many people. It's real. ""I see like you 2 freq for one channel both one on two is delete by itself. "" I explained it, note that work like it for my ultra If i do a auto scan and after i do a blind scan , i have now some channel in double, when i select for listen a channel in double and select the other immediatly after(take time to autoroll and see picture)one of this two double channel disappear(""deleate by itself"") Read it with Cartier1 problem on bin without 01 06 00 provider: https://www.ecoustics.com/electronics/forum/home-video/464111.html That proof what i say Thanks and reply on this Please |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1218 Registered: Jan-08 | Sorry Rtap if i hurt you. Without joke Sorry |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1232 Registered: Jan-08 | King I retry my first post and that does not work any more. it seems i have same problem as all. Now i tried to delete sat and autoscan and i lost many channel, after i do a blind scan and many channel is lost. I decided to doing a hard reboot and boom "no channel on box" I reload last bin and scan all sat again and come back with the issue. |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1235 Registered: Jan-08 | OK with autoscan on all sat, all is come back and all channel is there. |
