More than 24 hours epg?...
Username: Legend_killer
Post Number: 67
well im hearing that some people have 7 day epg and just wanted to know if any of you have it, cause mine is set to 24 hours which is the maximum.
i have a viewsat platinum.
this is quoted from another thread in this forum.
"To get a 7-Day Guide on Dish 110 and 119, press the SAT button on your remote.
Highlight "Dish Package" and press "OK".
If you don't have both 110 and 119, then select the Dish Sat that you do have.
Exit out of the menu and Press the Guide button.
Press the "FIND" button while in the guide and leave it sit on that channel for a few minutes.
The longer it sits, the more EPG will fill up, 7-Days max."
any truth to that?
Username: Saqeeb9000
Post Number: 2943
BEV 91 - channel 218
DN 119 - channel 200
depends on what dish u have..
i always go to wgn channe on both dn (119 dish )and bev same channe and hit epg button on my nfusion (don't know if viewsat pla ) has this ..
if not.. then just watch the channels for 5 minutes you will get better epg...
Post Number: 68
i only have dish and i do have 119 so where is wgn or what should i do?
Post Number: 2945
channel number 239 wgn ...
Post Number: 69
it won't work because its set on 24 hours epg right? there isn't a away i can change that?
sada do u get 7 days epg?
Post Number: 2949
no only for 2 days ....
