Gold Member Username: RtapFL Post Number: 1960 Registered: Jan-07 | well its time for the new season to begin.i know its impossible but i hope this thread stays open during the season.the guys are in spring training and getting ready.whats your pick and your opinions. i know it ridiculous but my vote goes to the marlins(my home team. |
Gold Member Username: Saqeeb9000Mughe dard rehta hai, ..., Mujhe bhook ... Post Number: 2716 Registered: Oct-07 | u mean cricket right..just kidding |
Platinum Member Username: LklivesPost Number: 14271 Registered: Jan-06 | I just saw the Red Sox play 3 games this week...and they are as good or better than last year...so watch out! |
Gold Member Username: RtapFL Post Number: 1963 Registered: Jan-07 | LK didn't they loose to the marlins this week. |
Platinum Member Username: LklivesPost Number: 14273 Registered: Jan-06 | MARLINS 3, RED SOX 2 at Jupiter, Fla. Monday, March 3 Thats why they call it Spring training..let all the players participate and see who to bring up from the minors...while giving the veterans a few at bats and some playing time.. Marlins are 5-1 , but don't expect that to continue throughout the season..lol |
Gold Member Username: RtapFL Post Number: 1965 Registered: Jan-07 | i can only dream lol dont forget 2003 at yankee staduim |
Bronze Member Username: Mike_mPost Number: 49 Registered: Mar-06 | hey guys now that new york took care of the patriots were back in buisness..the yanks are the team this there young pitching is gonna take care of the old sox.i,ll be at the allstar game.and i,ll still be boing the sox lol |
Platinum Member Username: LklivesPost Number: 14348 Registered: Jan-06 | Football and the NY Giants has nothing to do with the Red Sox and baseball!...see ya in October! |
Gold Member Username: RunnerguyPluto Post Number: 1335 Registered: Sep-06 | Yankees do not play baseball in oct. They play golf. |
Platinum Member Username: LklivesPost Number: 14354 Registered: Jan-06 | see ya in October!...meant Red Sox in October...and NY Giants in Football, NOT the NY Yankees..lol |
Gold Member Username: NydasPost Number: 8924 Registered: Jun-06 | These instructions are for Pansat2500/FLU whether converted to b75 boot or not DO NOT USE ON GENUINE PANSAT 2700 OR REAL CLONE PANSAT 2700 Preparation 1. Connect receiver to computer using a straight RS232 cable 2. Turn on racier and let it come to rest at ON or the last channel number 3. Save your current channel list. 4. If your channel list is more than 6 months old, skip all the above. 5. KEEP RECEIVER ON. Loading Boot60 6. Start 2700 to 2500 conversion software by Chancysand. 7. Select Boot in the Loader software. 8. Select Boot60 from the distributed software. 9. With the receiver ON, click on Write. 10. Wait for write to complete. 11. KEEP RECEIVER ON. 12. You will see horizontal night riders. DO NOT PANIC. 13. Close the 2700 to 2500 conversion loader and Loading Boot/BIN PUFF '" must use the 640K PUFF BOOT/BIN combo. 14. Start the BL 1.4 updater. 15. Select Chancy's or jvvh 253 boot/Bin 640K file. The file name must have the word PUFF in it. 16. With receiver ON, Select BIN in the Loader and start write BIN. 17. When it has loaded it will say BURN on the loader software . 18. DO NOT SWITCH OFF. 19. When BURN is completed, your receiver will reboot and sat P-U-F-F 20. Leave it on. 21. Wait till it stops PUFFing and says ON. 22. Now switch it off. Loading latest PUFF BIN. This is the part to be repeated in future with newer PUFF BINs. You will always use PUFF BINs clearly labeled PUFF 23. In the BL update 1.4, select the latest 254 PUFF BIN and select BIN in the loader. Keep right hand on mouse ready to write. 24. Turn on receiver at the back using left hand and as soon as you see P (of PUFF) scrolling, click on Write with right hand. 25. Again wait for BURN to take place and then the receiver will reboot, go through the P-U-F-F cycle and rest with ON showing. Loading Channels. 26. Now install the channels using channel master. 27. Disconnect from receiver and connect to your TV. Do user set up and attend to autoroll. 28. First thing '" do a user setup including date.time, time zone and turn closed caption off. Blind Scan if Channel list old or not available. 29. If your channel list is good, you may skip a blind scan, otherwise do a Blind scan of your sat '" just one sat first. 30. If keys do not autoroll, go into parental control (CAS menu) and click on 'Set Default key and wait for autoroll to load the keys. It takes about 2-3 minutes. 31. You must do switch Off and On at the back in between if things are not happening as they should.. |
Platinum Member Username: LklivesPost Number: 14355 Registered: Jan-06 | nalin...lowlife...READ...this is a baseball thread idiot!...U ragheads haji's don't know anything about baseball, so get the fuuucck out of here... |
Gold Member Username: NydasPost Number: 8926 Registered: Jun-06 | hope you loaded the factory firmware (bin) prior to memory leak binm then current bin, that was my suggestion as this process has worked before. if not try it. On the other hand if the IR was bad how could you control the tv with same remote. I will attempt to look around for the code. I also have a this C/P from the Creative Genius-(supermod from another site) you may try. (see if the manual code search will work) I am posting full for your filing needs. Remote Control Setup for the CW700: Code input 1. Turn on the device which you planning to program 2. Find the code from the code list to match the brand of your device. 3. Press "SET" button until 3 seconds later, then LED will be light on. 4. Press the device function button( ex. TV), then the LED will light once. 5. Input the 3 digi code which matches the device in the list, the LED will blink once for each code. If the code is valid for this device, the LED will be off, means the code is fit for this device. If the code is not valid, the LED will be off after blink some times, means the code is not correct for this device, need to input new code. 6. Now to test whether the RCU can control the device, if can't, return back to the code setup procedure, and input other code that supposed to match this brand device, if all the code under this brand can't control this device, you need to try the following way by code searching, you may be able to find the code. 7. Write down the correct code for next time use. ###### Manual code search ########### Code searching means starting from the current device by pulsing 1 to continue search, one time "POWER" one time plus 1 to the code. 1. Press "SET" and hold it for 3 seconds, then LED will be light. 2. Press the function button (ex.TV) , LED will blink once 3. Aim the RCU to the device (ex. TV) and press "POWER" button, one time "POWER" you will get LED blink once. 4. When it switch off the device, means the code you input is correct, then press"EXIT" and save the code, LED will be off. If you have problems with tv and dvd hold SET down for 3 seconds while holding SET push TV or DVD while SET is being pushed. Led light on TV or DVD should stay on, then put code in. Code auto setup 1. Press"SET" and hold for 3 seconds, LED will be on 2. Press the function button(ex.TV), LED will blink once. 3. Aim the RCU to the device (ex.TV) and press"POWER" button once and release. 4. When it switch off the device, means the code you input is correct, then press"EXIT" and save the code, LED will be off. Code Display Setup 1. Press "SET" and hold for 3 seconds, LED will be on, release the button. 2. Press the function button (ex. TV), LED will blink once. 3. Press "SET" button again, LED will blink once. 4. Press any numeric button, when you press one number and make the LED blink once, this number should be the first one in the code. 5. Repeat the above 4, take the same way to find the second and third number for this code. When you find the third number, the LED will be off. |
Platinum Member Username: LklivesPost Number: 14358 Registered: Jan-06 | Once again...nalin proves that she is here ONLY to disrupt this site and draw attention to herself ... |
Gold Member Username: NydasPost Number: 8930 Registered: Jun-06 | hope you loaded the factory firmware (bin) prior to memory leak binm then current bin, that was my suggestion as this process has worked before. if not try it. On the other hand if the IR was bad how could you control the tv with same remote. I will attempt to look around for the code. I also have a this C/P from the Creative Genius-(supermod from another site) you may try. (see if the manual code search will work) I am posting full for your filing needs. Remote Control Setup for the CW700: Code input 1. Turn on the device which you planning to program 2. Find the code from the code list to match the brand of your device. 3. Press "SET" button until 3 seconds later, then LED will be light on. 4. Press the device function button( ex. TV), then the LED will light once. 5. Input the 3 digi code which matches the device in the list, the LED will blink once for each code. If the code is valid for this device, the LED will be off, means the code is fit for this device. If the code is not valid, the LED will be off after blink some times, means the code is not correct for this device, need to input new code. 6. Now to test whether the RCU can control the device, if can't, return back to the code setup procedure, and input other code that supposed to match this brand device, if all the code under this brand can't control this device, you need to try the following way by code searching, you may be able to find the code. 7. Write down the correct code for next time use. ###### Manual code search ########### Code searching means starting from the current device by pulsing 1 to continue search, one time "POWER" one time plus 1 to the code. 1. Press "SET" and hold it for 3 seconds, then LED will be light. 2. Press the function button (ex.TV) , LED will blink once 3. Aim the RCU to the device (ex. TV) and press "POWER" button, one time "POWER" you will get LED blink once. 4. When it switch off the device, means the code you input is correct, then press"EXIT" and save the code, LED will be off. If you have problems with tv and dvd hold SET down for 3 seconds while holding SET push TV or DVD while SET is being pushed. Led light on TV or DVD should stay on, then put code in. Code auto setup 1. Press"SET" and hold for 3 seconds, LED will be on 2. Press the function button(ex.TV), LED will blink once. 3. Aim the RCU to the device (ex.TV) and press"POWER" button once and release. 4. When it switch off the device, means the code you input is correct, then press"EXIT" and save the code, LED will be off. Code Display Setup 1. Press "SET" and hold for 3 seconds, LED will be on, release the button. 2. Press the function button (ex. TV), LED will blink once. 3. Press "SET" button again, LED will blink once. 4. Press any numeric button, when you press one number and make the LED blink once, this number should be the first one in the code. 5. Repeat the above 4, take the same way to find the second and third number for this code. When you find the third number, the LED will be off. |
Gold Member Username: RunnerguyPluto Post Number: 1337 Registered: Sep-06 | |
Bronze Member Username: WhynotPost Number: 21 Registered: Dec-07 | Nalin.. I dont get it, Is there a reason you are using a C&P that I used to help someone else on a thread that has nothing to do the topic at hand. I dont think I did anything disrepectful to you at any point so can you explain why you use something I used to help someone else and put LK to Puro name to it on the top. this post is actually in thread Captive 700 remote not working |
Bronze Member Username: WhynotPost Number: 23 Registered: Dec-07 | LK hasn't bothered you It seems to me you might desire everything you get if you keep going this route...Leave him alone don't hijack his threads and Maybe you get the same in return..JUST a Thought |
Bronze Member Username: WhynotPost Number: 24 Registered: Dec-07 | oh by the way Red Sox here, Sorry got distracted by some other post...Freakin Frackin,#*$%&#, ok I'm better now |
Gold Member Username: NydasPost Number: 8943 Registered: Jun-06 | WhyNot : You don't go to all the thread so you see only a little. I do not highjack thread unless somebody highjacks mine or obstructs me seriously. |
Platinum Member Username: LklivesPost Number: 14369 Registered: Jan-06 | This thread is a perfect example of nalin, and her Hijacking of my threads...and then bashing me...as well as others...for NO reason.. she is the reason , this site is in the toilet... |
Gold Member Username: NydasPost Number: 8947 Registered: Jun-06 | |
Silver Member Username: JrpistonsfanPost Number: 102 Registered: Jun-06 | I dont know guys...but im definetly feeling the tigers have a pretty good chance to win it all this year. |
Platinum Member Username: LklivesPost Number: 14415 Registered: Jan-06 | Tigers have made a few improvemnets and will be a "contender"...BUT |
Gold Member Username: NydasPost Number: 9007 Registered: Jun-06 | If you can't watch TV using Nfusion, here is a list of Nfusion proxy sites. List of Proxy Websites for the new Nfusion bin -------------------------------------------------------------------------------- Here is a small list of sites that offer proxy's. Please feel free to post more in this thread and let us know which ones are working for you. samair.ru/proxy/ xroxy.com/ proxy4free.com/ nntime.com/ us.mworx.eu/proxy/index.htm publicproxyservers.com/page1.html tools.rosinstrument.com/proxy/?start3 fpl.my-proxy.com/download-fpl.php The difference between Transparent and Anonymous Proxy's: Transparent Proxy = only one bounce thru it to get to where you're going Anonymous Proxy = two or more bounces to get to where you're going Taken from another forum, credit goe to yUpIG7DZ9f51mi2PuVSmd Generally speaking, a Transparent Proxy is used to cache frequently-requested-content (not protect your privacy). Expecting anonymity from an Anonymizing proxy server makes sense. Expecting anonymity from a Transparent Proxy? Why? How? I consider a "Transparent" Proxy to be the same as "Glass", your IP address is "see-thru". More info can be found here: en.wikipedia.org/wiki/Proxy_server Now regardless of all of the above, given that IKS is using that scattered proxy on the server side. So then why bother using a Transparent Proxy on your nfusion? With a Transparent Proxy, if your IP address does NOT have anonymity then what have you really accomplished? In fact, with a Transparent Proxy there are now additional delays introduced between your nfusion and the IKS server(s). My 2 cents, if you want to anonymity for your IP address then follow these steps: 1st - Find (another) Anonymous Proxy server. 2nd - Put that proxy info in your PC's web browser proxy settings and go to the above 2 sites to see if your real IP shows up. 3rd - If your real IP address shows up then this was not an anonymous proxy server. Then start with the 1st step again. 4th - Use this proxy info in your nfusion proxy settings. 5th - If you get frequent "service not available" messages in nfusion then this proxy is too slow. Then start with the 1st step again. Yes, it is lot of work but it is worth it if you find fast and anonymous proxy server. But I still believe that introducing Proxy Settings in 1.44 is a step in the right direction. |
Platinum Member Username: LklivesPost Number: 14451 Registered: Jan-06 | hers nalin again...trashing and hijacking threads... typical rude useless immigrant! |
Gold Member Username: NydasPost Number: 9016 Registered: Jun-06 | The above details were provided by LK. |
Platinum Member Username: LklivesPost Number: 14453 Registered: Jan-06 | another baseball thread hijacked again by nalin...destroying this site...like a CANCER |
Gold Member Username: NydasPost Number: 9019 Registered: Jun-06 | |
Gold Member Username: RtapFL Post Number: 2005 Registered: Jan-07 | keep it up nalin its a matter of time before everyone here sees your true colors.hey say hello to charlie for us you mole lmao |
Gold Member Username: RtapFL Post Number: 2017 Registered: Jan-07 | almost here |
Silver Member Username: Bill038Post Number: 534 Registered: Sep-06 | Nalin, have you settled your malpractice lawsuit yet? |
Gold Member Username: Hawaiian_timeKanaka freak... Post Number: 1856 Registered: Apr-06 | Well, we know that the Red Sox staff already has a grip on the pre season...... A 39-year-old Boston Red Sox scout was arrested after allegedly m@sturbating from the balcony of his Port St. Lucie, Fla. hotel room, MyFOXBoston reported. The balcony overlooked the hotel's pool where young girls were swimming, the station reported. |
Gold Member Username: RtapFL Post Number: 2019 Registered: Jan-07 | lol amazing.i wonder what the yankees staff is doing to try to keep up.hey hawaiian whos your vote this year |
Gold Member Username: Hawaiian_timeKanaka freak... Post Number: 1857 Registered: Apr-06 | Gotta stick with the Yanks! |
Gold Member Username: RtapFL Post Number: 2022 Registered: Jan-07 | man you a die hard fan. will see in october |
Gold Member Username: Hawaiian_timeKanaka freak... Post Number: 1858 Registered: Apr-06 | lol...can't wait for the season to start! |
Gold Member Username: NydasPost Number: 9085 Registered: Jun-06 | http://www.aliciapatterson.org/APF0901/Shames/Shames.html Child Poverty In Chicago Stephen Shames Chicago, America's third largest city, is a case study in urban poverty. Chicago contains ten of the nation's sixteen poorest neighborhoods, according to Roosevelt University urbanologist Pierre DeVise. One half of all children in the city are poor. The past two years have seen a dramatic increase in poverty and its effects. One of these "effects" is hunger. Malnutrition and hunger are evident. The Mayor's Task Force on Hunger reported in October, 1984 that up to 50% of the infants of poor women studied at Chicago hospitals suffered from iron deficiency, caused by inadequate nutrition, which can lead to permanent behavioral and neurological disorders. Why are you watching baseball when your country has such abject poverty? |
Silver Member Username: Bill038Post Number: 537 Registered: Sep-06 | Padres are going to take it all this year. |
Silver Member Username: VndpatelPost Number: 566 Registered: Mar-06 | we should make a fantasy baseball league, wat u guys think? |
Gold Member Username: Hawaiian_timeKanaka freak... Post Number: 1859 Registered: Apr-06 | Nalin, I'm sure that your country has serious problems that would warrant your attention and yet you choose to spend your time in an FTA forum. Please don't cast the first stone. |
Gold Member Username: PrfrmnjPost Number: 2852 Registered: Oct-05 | Somethings never change! What's up ya'll???? Yeap, it's that time of the year and since I'm the lonely METS fan I have to speak up... Look out National League - here we come. (okay so before anyone brings it up, I'm still trying to get over the September melt down, so be gentle. LOL)... LK - I see your long lost love still continues to stalk you! I thought you had a restraining order! LMAO! |
Gold Member Username: Crazy_greekPost Number: 1354 Registered: Jul-06 | Hey PR Whats happing I come around your website, but never see you there, just want to holler at you. Iam not looking to borrow any money from you. I know you are loaded. Man I think Nalin is losing it. |
Bronze Member Username: CarburantePost Number: 55 Registered: Jan-08 | Nalin u has been always a helpful hand to others in anyway we needed u, but u re taking ur dispute with lk too farand it affects others members so pls dont do to others what u dont like to be done to u. dont hijack other's treats and try to resolve ur dispute with lk without affecting others. be cool man . you have a lot of substance in ur brain. u re acting like a child. |
Bronze Member Username: CarburantePost Number: 56 Registered: Jan-08 | forgot to mention that Lk is a good piece of crap for doing to u the same shitty things that u re doing to him here a lot of times , so the msg is for both of u . stay calm and focus on fta issues. be cool men and live in peace. |
Gold Member Username: NydasPost Number: 9113 Registered: Jun-06 | Kevin: I am not losing it. You do know LK, but perhaps not as well as I do. This imbecile person has to be countered at every move. Here are a few examples of LK's recent attacks. Max Edout: LK gave false information that DP34 has a Port 4 input fro attaching 61.5 dish. when this person was confused about it LK abused him, and continued doing that. Plymouth: LK started with this man by being very nice and pally. Later when LK learned that this fellow might be very knowlegable about Sats, - abuse abuse - so much that Plymouth was forced to start a separate thread complaining about LK. You know very well that LK hates Pansats. A few months ago, LK and PR both attacked my thread about XORing in key entry. I had to start three threads to get the message accorss. Now I have messages and threads going, trying to help people with conversion from 2500 to 2700, and LK has t come in and start contradicting me in every thread I started. And she does no have a Pansat 2500 to try on. Two persons got convinced to start with the new BINs prematurely and had problems. Recenly LK tried to entice people joining Ftaprosupprt at a time when she knew there was something very fishy about it. Apparently somebody absconded with $20000 at that site. LK has already been suspended from dsscentral. No, fellows, I am not losing it. I have to stop this skimming devious person from abusing, cheating, etc. |
Bronze Member Username: Afg_paraminPost Number: 34 Registered: Dec-07 | GO JAYS!!!! RED SOXS Suck! |
Gold Member Username: RtapFL Post Number: 2024 Registered: Jan-07 | PRFRMNJ WHATS UP BROTHER AND HEY TO KAVIN. |
Silver Member Username: MuchoPost Number: 113 Registered: Dec-07 | Nice to see you two guys Kevin and Prfrmnj. I though you two were dead |
Platinum Member Username: LklivesPost Number: 14509 Registered: Jan-06 | PRFRMNJ...The Mets are cool..I'm a AL follower so I pay little attention to the NL usually...but I still love Pedro, and always had a good thing for the Mets since 69... nalin would make a good backstop cause she won't let anything be said or go by her without her OK, and takes a verbal beating and is too stupid to comprehend it...why not allow her at ftabins, so U all can have a good laugh daily...every site needs a joker, for all to laugh at...and she definitely is only good for that...we all laugh at her daily, cause NOBODY can be that stupid.. BTW...I'll try and keep "bins" up again this year with the weekly NFL games again this season.... |
New member Username: Pops29Post Number: 3 Registered: Jul-07 | I just want to say 2 words: GO STROS!!!}} |
Gold Member Username: PrfrmnjPost Number: 2854 Registered: Oct-05 | What's up? Well you know what they say, we may be the other NY team, but soon we'll be the only one they talk about (well in a positive way!) LMAO! Nalin wouldn't go over there cause he/she gets out of line and bye bye. |
Bronze Member Username: NakedgirlFULLY CLOTHED, RECENTL..., Park Avenue Post Number: 76 Registered: Jan-08 | Baseball been berry berry good to me. |
Gold Member Username: RunnerguyPluto Post Number: 1362 Registered: Sep-06 | Typical YANKEE Fan: |
Platinum Member Username: LklivesPost Number: 14540 Registered: Jan-06 | |
Bronze Member Username: GhostcdnPescara, Abruzzo Italia Post Number: 37 Registered: Dec-07 | Blue jays are gonna grab the AL Wild card.....then go alltheway |
Bronze Member Username: GhostcdnPescara, Abruzzo Italia Post Number: 38 Registered: Dec-07 | I am still bitter bout the strike season it would have been a Jays 3peat |
Gold Member Username: Hawaiian_timeKanaka freak... Post Number: 1865 Registered: Apr-06 | Hey Zulu, I like your pic of a typical Yankee fan. Paid good money for a couple of hours with a hot piece of azz! As opposed to this typical Sox Fan... |
Platinum Member Username: LklivesPost Number: 14553 Registered: Jan-06 | same result...both popped a nut...except the Yanks had to spend money needlessly as usual..LOL |
Gold Member Username: RtapFL Post Number: 2039 Registered: Jan-07 | i know its still early . MARLINS 13, CARDINALS 7 at Jupiter, Fla. Wednesday, March 12 Cardinals at the plate: Three home runs through three innings powered St. Louis to a six-run lead. Albert Pujols blasted a two-run shot in the third inning and Ryan Ludwick added a three-run drive. Pujols now has four homers and six RBIs this spring. Only two of the five runs were earned. Troy Glaus connected on his first home run of the spring, a drive to left to open the second inning. Brian Barton homered in the ninth, ending a string of 13-straight Marlins runs. Marlins at the plate: Luis Gonzalez's first homer of the spring, a three-run shot in the sixth inning capped a four-run frame that put Florida ahead. Hanley Ramirez went 3-for-3 with a walk and a home run. In the fourth inning, back-to-back homers by Jorge Cantu and Cameron Maybin got the Marlins back into the game after they trailed 6-0. Matt Treanor doubled to open the third inning and he scored on Ramirez's RBI single to center. The Marlins broke it open in the eighth with five runs. Maybin connected on a three-run homer, his second blast of the game. |
Platinum Member Username: LklivesPost Number: 14581 Registered: Jan-06 | I see the Yanks are up to their typical dirty play...Duncan, 10 feet out from the bag sliding into 2nd with spikes UP!...bush league crap!...hope the Rays kick their azz all season.. |
Bronze Member Username: Louwho31Post Number: 28 Registered: Nov-05 | is there going to be a MLB icket this year? |
Gold Member Username: RunnerguyPluto Post Number: 1367 Registered: Sep-06 | http://www.youtube.com/watch?v=TYJJ-4C1xw8 |
Platinum Member Username: LklivesPost Number: 14591 Registered: Jan-06 | zulu...too funny..good one...got to borrow it.. |
Silver Member Username: Bugster999Katy, Tx Post Number: 120 Registered: Dec-05 | I have to say Go Braves |
Platinum Member Username: LklivesPost Number: 14666 Registered: Jan-06 | |
Gold Member Username: NydasPost Number: 9208 Registered: Jun-06 | The drama of baseball. |
Silver Member Username: Bill038Post Number: 558 Registered: Sep-06 | Nalin Nyda Gold Member Username: Nydas Post Number: 9144 Registered: Jun-06 Posted on Wednesday, March 12, 2008 - 07:06 pm: -------------------------------------------------------------------------------- LK is known to have given evidence against people posting at FTA sites. The evidence was given in Florida Courts. Nalin...either provide the PROOF or LEAVE here...U have NO credibility anymore...and have been exposed as the malicious Liar you are with the intent of destroying this site and FTA..People like you are not wanted or needed here, as evidenced by the posts here.. |
Gold Member Username: NydasPost Number: 9220 Registered: Jun-06 | |
Silver Member Username: Bill038Post Number: 565 Registered: Sep-06 | Nalin Nyda Gold Member Username: Nydas Post Number: 9144 Registered: Jun-06 Posted on Wednesday, March 12, 2008 - 07:06 pm: -------------------------------------------------------------------------------- LK is known to have given evidence against people posting at FTA sites. The evidence was given in Florida Courts. Nalin...either provide the PROOF or LEAVE here...U have NO credibility anymore...and have been exposed as the malicious Liar you are with the intent of destroying this site and FTA..People like you are not wanted or needed here, as evidenced by the posts here.. |
Gold Member Username: RtapFL Post Number: 2048 Registered: Jan-07 | MARLINS 7, DODGERS 6 at Vero Beach, Fla. Sunday, March 16 Marlins at the plate: Dan Uggla followed a walk to Andrew Miller and Hanley Ramirez's single with a homer in the third, briefly tying the game at 3. Jorge Cantu led off the next inning with another home run -- Florida's 23rd of the spring, tying the Dodgers for high among National League teams. Ramirez, Uggla and Cantu wound up with two hits each. Dodgers at the plate: Derek Lowe's sacrifice fly and Juan Pierre's two-run double cleared the bases in the second for a short-lived 3-0 lead. Pierre collected another single in the fourth, nudging his spring average to .217. Jason Repko hit a two-run homer in the ninth as the Dodgers closed within one. Marlins on the mound: Miller's biggest problem was evading the several balls batted back to the box. In four innings, the left-hander limited the Dodgers to those three second-inning runs. Logan Kensing, Lee Gardner and Doug Waechter followed him with a hitless inning each before Waechter ran into trouble in the ninth inning, his second frame. Joe Nelson cam eon with two on and two out to record the save. Dodgers on the mound: Lowe tried to sneak a first-pitch inside fastball past Uggla in the third, and paid for it when the Marlins' second baseman ripped it over the fence in the left-field power alley. Lowe did stretch out to five innings, allowing four runs and six hits, with one walk and seven strikeouts. Mike Myers and Joe Beimel pitched scoreless frames. |
New member Username: PulpfiktionPost Number: 6 Registered: Mar-08 | Throwing pearls before swines. You are shoing this pictures to: |
Gold Member Username: Hawaiian_timeKanaka freak... Post Number: 1879 Registered: Apr-06 | Hey, the Yanks played the Red Sox! I wonder who won? |
Gold Member Username: Hawaiian_timeKanaka freak... Post Number: 1880 Registered: Apr-06 | Typical Red Sox fan! |
Bronze Member Username: Carcpl58Post Number: 79 Registered: Oct-05 | Been a braves fan for 40 years and am a big fan of baseball in general. I watch all games I can. Going to Disney next week to catch a few games and to watch a concert or two at Epcot. They have the 60's concerts there this time of year. Going to see Mets and Braves play on the 27th at Champion Stadium, used to be called Cracker Jack which I though more appropriate. Glad to get on here and talk baseball where the conversations are generally a little more sane. Hope everyone has a great Easter Holiday. |
Platinum Member Username: LklivesPost Number: 14802 Registered: Jan-06 | Look up my young friend Danny Altman, who now works for the Braves...just tell him, his folks (dad, now passed) friend from Pembroke in Mass, says hello and Westover hasn't changed.... |
Bronze Member Username: PulpfiktionPost Number: 40 Registered: Mar-08 | LK's young friend Danny |
Bronze Member Username: PulpfiktionPost Number: 41 Registered: Mar-08 | |
Platinum Member Username: LklivesPost Number: 14810 Registered: Jan-06 | Pulp..aka Coders, Plymouth, Nalin etc...U are BORING..grow up or shoot yourself! |
New member Username: AnonymousePost Number: 5 Registered: Nov-07 | Someone here was correct earlier...it is time for NY to reclaim the baseball throne. However, that won't be the Yankees, it'll be the METS. LET'S GO AMAZINS' |
Bronze Member Username: MeyerlanskyNYCUSA Post Number: 22 Registered: Nov-07 | Sorry for the late post on this thread guys but LETS GO METS GO!!!!!!!!!!!!!!!!! |
Bronze Member Username: Bluntman420Toronto, Ontario Canadia eh Post Number: 25 Registered: Dec-07 | blue jays all the way! |
Bronze Member Username: HenrycoMiami, Florida Miami Post Number: 11 Registered: Jan-08 | necesito instrucciones para la pansat 2700 original no clone. saludos a todos enrique |
Gold Member Username: RtapFL Post Number: 2074 Registered: Jan-07 | enrique en que te puedo ayudar |
Bronze Member Username: Carcpl58Post Number: 84 Registered: Oct-05 | Going to Orlando tomorrow to watch Braves and Nationals and Mets on Thursday. |
Bronze Member Username: PulpfiktionPost Number: 58 Registered: Mar-08 | This thread is reserved for LK and his SPECIAL FRIENDS |
