Take your remote find up and down right and left, the OK button and Exit. Get the feel of it for entering menus and sub menus and go through all your settings and prefrences. Blindscan should be avoided or last option due to channel dups make EPG a mess (no info)on every other channel. Remember some will get some wont with spot beam TPs.Should get between 300-350 tvchs per on main sats.
First set your dish settings/ Menu/ OK/0000/Installation and then set all your sat settings and save
Hit menu on remote control/Installation/ OK/ 0000/ Scroll down to Channel Scan/OK/Satellite/OK/scroll to Sats and press OK on each Sat you want to scan / OK to put a heart beside each sat that you have setup outside / once done press the Menu key again/Scroll down to Multiple Sat Search/press right arrow key to get the search feature/ OK and all your Sats will scan in one run
If ya want to learn more about FTA and any receivers, U're gonna have to leave here and go to a reputable DSS site..this place has a MOLE and BUG infestation..
Posted on Tuesday, June 27, 2006 - 07:05 pm: Edit Post FTA is back...U want a war with me?...cause I'll chew U up and spit U out like the useless dog U are!
Nobody calls me a scammer and gets away with it!...I'll kill U and all your buds!....I have NO fear of death myself like U do!....I've been there many times already pal...and I can kill U anytime and get away with it!...I deserve every penny of my VA comp...U crossed the line dead man..U aren't the first I have killed!...just another useless POS breathing my air!
I'm going to get U Muther foucker!...I'm pissed!...I will destroy your computer and identity first...then I will get U personnally...U better be watching your back punk all the time, and I hope U can sleep with your eyes open...U will be my crying shameless bit*ch...U went too far...I own U now punk!...start getting your affairs straight!
