Read the attached court documents......Not off to a good start for the FTA manufacturers..... Motions dismissed and denied.
Viewsat ( Viewtech) and Coo*lsat (Freetech) lose their motions to dismiss, and Pansat (Panarex) case also moves forward towards "discovery" and following procedures....
Echostar basically has maintained that not only do these companies manufacture the receivers, but also are involved with the creation of the necessary and pirated software used to provide access to the needed keys and encryption..
hey Nalin...U and your people/aliases here above, won a victory in court,....I'm sure U , Plymouth, Coder, and all you DN moles will be very happy about this...
I believe/know Nalin and all her aliases to be associated with this site and Dishnet...I've been saying this for years here, but nobody appears to listen..
its so obvious, that any blind man can see this..
U people have been seriously monitored , as well as any FTA news and file info posted here..
The on;y virus here is Nalin, Plymouth and every other alias , they use..
-------------------------------------------------------------------------------- Read the attached court documents......Not off to a good start for the FTA manufacturers..... Motions dismissed and denied.
Echostar basically has maintained that not only do these companies manufacture the receivers............(No problem here, they are manufacture to receive Radio and TV from FTA Satellites)...............
but also are involved with the creation of the necessary and pirated software used to provide access to the needed keys and encryption............ (How are they going to prove that?)}.............
