Wondering how to get some channels..
Username: Ariza
Post Number: 235
Can someone tell me how to get Clips, shorteez, fresh!, and spice xcess?
Currently i get Ten, Xtsy, Jenna, and Play boy TV
Fresh! moved to another channel just before i discovered it LoL
Username: Metallica
Post Number: 346
TCLIP-488
Shorteez-487
Fresh-493
Spice xcess-492
Tenclips-494 the same with Tclip.
do a blindscan...on Echo 8,10 110W
Username: Ariza
Post Number: 243
okay i'll try that out.. so far no results on echostar 8,10 when doing a blind scan.. didn't scan any channels.. came out with no results
Username: Metallica
Post Number: 392
Jib try this..
polarity...go for vertical
Blind scan..all
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 1104
I dont take this channel too
Username: Madflea168
Post Number: 366
do you have a lot channels on 110? if not, maybe you will need to skew a bit to get stronger signals in.
Username: Plymouth
Post Number: 1105
Mad or Metallica do you have complete info on this channel like example 12342 20000 V 5/6
V 4642 A 4643 P 4642
Username: Metallica
Post Number: 395
Plymouth there are a few p@rn channels have been changed 2 days ago to the different channel..you need to do a blind scan to get it...on Echo 8,10.
Username: Metallica
Post Number: 396
Plymouth what channel do you need?
Username: Plymouth
Post Number: 1106
OK i try it
Username: Plymouth
Post Number: 1107
TCLIP-488
Shorteez-487
Fresh-493
Spice xcess-492
Tenclips-494
Username: Plymouth
Post Number: 1108
How many channel i'm supposed to receive on 110W
Username: Metallica
Post Number: 397
TCLIP-488..12253 v 20000 5/6 v6178 a6179 p6178
Shorteez-487..12253 20000 v 5/6 v5154 a5155 p5154
Fresh-493..12516 20000 v 3/4 v5154 a5155 p5154
Spice xcess-492..12486 20000 v5/6 v4898 a4899 p4898
Tenclips-494..12253 20000 v 5/6 v6178 a6179 p6178..
Username: Metallica
Post Number: 398
110W...i got 300 channels
119W...i got 280
Username: Plymouth
Post Number: 1109
On 110 i got 351 TV and 4 radio
On blind scan i found Fresh and Spice only
These 3 are on 110w or 119
Username: Ariza
Post Number: 245
im only getting international channels on Echostar 8,10
Username: Plymouth
Post Number: 1110
How is youre signal and quality
Username: Plymouth
Post Number: 1111
Jib did you try to delete 3 Dish provider like i says in the other thread
Username: Metallica
Post Number: 399
all these 3 channels are 110W.
Username: Plymouth
Post Number: 1112
I'm not able to catch it, i try to enter manualy
Username: Metallica
Post Number: 400
Plymouth...TCLIP-488 and Tenclips-494 are the same you don't need both...just get 1..
Username: Plymouth
Post Number: 1115
OK thats because the signal is too poor.
I have big three directly between my dish and 100w 119w and 121w 148W.
This summer i went relocalised my dish
Username: Plymouth
Post Number: 1116
I see that this is the same Tp info
Username: Ariza
Post Number: 246
for some reason the TP frequency never saves.. it always stays the same when i exit and go back into antenna setup.. always the same number.. why is that? Plymouth i didn't quite get you, what did you mean "try to delete 3 dish provider?"
Username: Metallica
Post Number: 401
YUH..just the channel name a little different...showing the same thing..
Username: Plymouth
Post Number: 1117
Jib Forget that, probably youre dish need to be aligned
Deleted dish provider is if your box lost channel and sat info, autoroll and freeze
Username: Plymouth
Post Number: 1118
Thanks very much Metallica and Jib now i know, i dont have all channel
Username: Metallica
Post Number: 402
No problem..night guys.
Username: Ariza
Post Number: 247
LoL i have to skew my dish. It's obviously not getting through to its full potential. The highest I'm getting for TV is 20 LoL
How hard is it to change the direction of the dish? It's not just the adult channels which is least important, but it's other channels and also BEV that i wanted to try out..
Username: Plymouth
Post Number: 1119
It's easy with a cheap satellite finder 20$ less and http://www.dishpointer.com/
Not need brought the receiver on the roof with it.
Username: Luser
Post Number: 146
What sat does lyngsat say those channels are on? Do you have a single or twin lnb? What type lnb? What are your settings for that lnb? What sat are you pointed at? How do you know your pointed at that sat? These are the questions anyone would have to know before troubleshooter or diagnosing channel problems.
Username: Nydas
Post Number: 9396
For over a year, every time I do a blind scan on 8.1 (110W), Those 5 channels come in.
Username: Chip_la
Post Number: 43
Hi
i am having problemns getting in PLyby and ten.using echo7 119,Viewst plat. Could someone give me the settings please. Also since I switched from kolsat 5000 to a viewst
plat i am not getting echo8-10 need these setting to please
Thanks
Chip
Username: Plymouth
Post Number: 1125
Ply boy is 12268 20000 H 5/6
V6434
A6435
P6434
Post Number: 370
my vs ok with auto scan to get those back.
486 gone
487 shorteez echo 8/10-12253-20000-V-5/6
488 tcclip echo 8/10-12253-20000-V-5/6
489 ten echo 7 -12268-20000-H-5/6
491 jenna echo 7 -12443-20000-H-5/6
492 spicexce echo 8/10-12486-20000-V-5/6
493 fresh echo 8/10-12516-20000-V-3/4
494 tenclips echo 8/10-12253-20000-V-5/6
495 ten echo 7 -12268-20000-H-5/6
496 tenxtsy echo 7 -12414-20000-H-5/6
497 pl tv us echo 7 -12268-20000-H-5/6
498 pl tv en echo 8/10-12341-20000-H-5/6
499 gone
hope this helps.
good luck.
Username: Plymouth
Post Number: 1127
For 8,10, post how many sat and LNB you have?
Post Number: 371
what is that mean?
I have only 110/118/119 on super d converted with dn lnbs.
Post Number: 372
I will go copy the rest of infos and post later.
Username: Plymouth
Post Number: 1128
Mad i ask it to Chip
Username: Chip_la
Post Number: 44
Hi
I don't know how to do a blind scan on a viewst plat.please help
thanks
chip
Username: Chip_la
Post Number: 45
Hi
Could some one tell me how to scan a tp I have been trying but my missins channels are not coming in. Missing plyby ten echo7 119 viewst plat
thanks
chip
Username: Plymouth
Post Number: 1133
If is it like Ultra do that:
Menu
Installation
Right arrow 0000 (pin code)
Channel scan
Arrow down 2 times
enter in edit TP
On remote F1 (Add user TP)
Put this: 12268 20000 H 5/6 and OK
Press OK again for scan
OK for save
Exit and save
Check if channel is There
If not
After this line: Put this: 12268 20000 H 5/6 and OK
Press F4 (Add use channel)
Enter in Video PID 6434
Down arrow enter 6435
Down arrow enter 6434
and OK
This is channel is call: 000UserChannel
Username: Chip_la
Post Number: 46
Plymouth
thanks did it now what ,I see user000, but no picture
thanks
chip
Username: Plymouth
Post Number: 1138
OK how is your signal and quality?
If you have no quality, you need to align your dish
Username: Luser
Post Number: 147
On viewsat extreme I found on channel scan, network search on It was mistaking polarity on several TP's. It looked like vhvhvhhhvhvhh. After changing any TP's that didn't have channels found and rescanned each with network search off I picked up 3 or 4 more TP's about 50 channels per sat.
Username: Chip_la
Post Number: 47
thanks
I will try that,Plymouths directions were great but the new channel that came up is blank even though there is 90% signal and 90%quality.
Thanks
Chip
Username: Tgyoung1
Illinois U.s.a.
Post Number: 18
I have 82 level 89 quality but when I blind
scan part of tranponders don't show up? I get alot channels on 110 and 119 with twin lnbs/dish 500.Get no speed channels or news channels like cnn..? help thanks.
Username: Tgyoung1
Illinois U.s.a.
Post Number: 19
pansat 2700a
Username: Nydas
Post Number: 9419
Delete all channels.
Disable DN Sats in antenna setup.
Scan All BEV sats first.
Disable BEV.
Set up and Scan all DN.
Enable BEV.
Hope it works
Username: Tgyoung1
Illinois U.s.a.
Post Number: 20
nvda
explain which sat are bev? need to write down the dn sats.to put satelite setup?
Username: Haboosh
Post Number: 12
i have echo 3 61.5 what channles should i get? on viewsatx? thanks
Username: Bte
Post Number: 22
hey guys, i was converting my 2500 to 2700 clone to PUFF and i have been stuck on (F) forever plz help asap!
Username: Plymouth
Post Number: 1184
Try a bin from another site, it seems like all bin is not same.
Username: Bte
Post Number: 24
can u give me a link to reliable website plz
Username: Plymouth
Post Number: 1185
Damdoom check this all channels are there:
http://www.satelliteguys.us/thelist/
Choose 61.5
Username: Plymouth
Post Number: 1188
Try dsstesterDOTcom and select in left side for your box.
At your risk, i dont know if it's that
Before ask to Nalin because i dont know your box.
Username: Bte
Post Number: 29
i am using pansat 2500 to 2700 clone and tried to convert it to PUFF(used the converting procdure provided). last thing i did was downloaded jvvh 258 nkk puff bin and the reciever stays on F plz help
Username: Plymouth
Post Number: 1191
Bill Nalin is one of first who start Thread on puff,
Sorry, i dont know nothing in puff. I read too fast and see just after "puff".
Start a new thread with "Need help Nalin"
and he help you fast.
Sorry
Username: Nydas
Post Number: 9429
For Pansat 2500/FLU new conversions and converted to 2700
Use only on unconverted 2500/FLU or converted receivers.
DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones
Everything you need for 2500/Flu to 2700 conversion in one package.
Instructions included. Either b75 boot or PUFF boot or PUFF_LZMA boot and matching BINs
http://public.box.net/2500_full_kit
Read the instructions properly in the section you have chosen.
PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS.
Username: Nydas
Post Number: 9430
If yu get stuck badly and th elight comes on, best to doa revert to 2500 and start all over again. There is another sophisticated recover from a problematic PUFF load
[link removed]
Username: Lajr
How do I get ATN Cricket Plus
