Why? Double channel on viewsat with blind scan
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 1205
By Plymouth
I found that because the frquency assigned by the bin is not the same like blind scan.
we just to choose this channel on both one after the other and that come automatically delete one of two. because we have some post on it.
It's not really a problem
autoscan give me 133 channel
blind scan give me 351 channel
It's better to blind scan
Now solution for it:
Note your sat info and go in channel scan and delete sat in bottom,
exit and return in antenna setup enter info you had note and exit and save
and blind scan
now you have all channel without double
thats all
Thanks
Username: Plymouth
Post Number: 1206
If you need more info just to ask and tomorrow , i give you answer
Thanks
I go to sleep
Goon night everybody
Username: Luser
Post Number: 148
If you look at the tp for each ch and one is V and one is H then likely you have DP lnb's and your getting regular and bandstacked. If this is true and you want the best possible scan/EPG do this. Go to lyngsat dot com get freq for sat tps then in channel scan menu check each manualy but for each horizonal subtract the # of the TP from 25600 and change it to vertical. Note: Lyngsat lists tps as L or R as opposed to H and V. Deal with it!
Username: Luser
Post Number: 149
P.S Make sure your type lnb setting is OCS-DP if your lnb has big black DP logo on the back. If it doesn't disregard previous post.
Username: Plymouth
Post Number: 1207
Semore i dont see the reason for this reply,
i know how change info on TP, no need to change nothing all channel is there.
Explaine it please.
If that not work, thats because the bin is not good.
I have universal Invacom LNB it dont work on OCS-DP
Thanks
Username: Chip_la
Post Number: 48
I am still not getting plyby and ten I tried tp scan and then I tried adding a user channel and eeven though it comes up with plenty of signal no picture anyone have a solution. echo7 119 vs plat
thanks
chip
Username: Tapeman
New York City in-HD, NY
Post Number: 2635
Plymouth
What yo don't know is providers got 2 streams side by side from 2 satellites along with the 2 freq spectrums
Lately I noticed the hide and seek frequency game
Nagra also added frequency conditional access change as new keys roll in
There is a lot more going on than yo and I can observe including unrepeated trial and errors many of them don't make too much sense at the moment which made me believe they are saving it to a later time
Username: Plymouth
Post Number: 1213
KING I dont have this problem since, i delete provider the first time.
The new solution for provider is not insert 01 06 00 in bin.
Bad bin is on different sites.
I see like you 2 freq for one channel both one on two is delete by itself.
Warning it seem bin is not good on all site.
King say if you went where you download your bin?
Thanks
Username: Rtap
FL
Post Number: 2068
its normal to duplicate channels when you perform a blind scan on any receiver.a couple of things you can do to minimize this problem.
1- if using a switch bypass switch and run cable directly to dish and scan.
2 - make a channel list and save.
Username: Plymouth
Post Number: 1214
Rtap you understand nothing on what we talk.
Please stay away.
This comment is useful has anything.
And you dont know our setup.
I give clearly the solution on this first post.
Thanks
Username: Rtap
FL
Post Number: 2071
LMAO plymouth now it seems you try to control all threads you post in.i was just trying to help this person as you were doing.i've been doing this longer than you have so step off.and the way you write confuses the hell out of anyone.lol
Username: Plymouth
Post Number: 1216
RTAP dont be worry.
Read that it's clearly explained:
and blind scan
thats all
Thanks
Username: Tapeman
Post Number: 2637
I tried all 3 bins
Dsstester, totalfta, ftahq they are all indenticall the same all made from one source
Sometimes older bins work well too
Like I said above try loading when there is no high traffic
Plymouth yo need to take it easy on other members
RTAP was right about blind scan
It's important to hear other members impact
Yo are mixing few things about provider 0106
Lately DN has been quite with recent ECMs for unkown reasons
Yo don't have freeze problems since yo deleted 0106 I also don't have feeze problems without deleting anything I think they are 2 isolated issues
I'm still not sure what yo mean by this?
"I see like you 2 freq for one channel both one on two is delete by itself. "
Can yo explain this one more time please?
Are yo talking about when yo do blind scan?
I don't get the part "delete by itself"???
Yo may have come across something I haven't!!!
Username: Plymouth
Post Number: 1217
No King it's not isolated, i help many people here and on a another site many many people. It's real.
""I see like you 2 freq for one channel both one on two is delete by itself. ""
I explained it, note that work like it for my ultra
If i do a auto scan and after i do a blind scan , i have now some channel in double, when i select for listen a channel in double and select the other immediatly after(take time to autoroll and see picture)one of this two double channel disappear(""deleate by itself"")
Read it with Cartier1 problem on bin without 01 06 00 provider:
https://www.ecoustics.com/electronics/forum/home-video/464111.html
That proof what i say
Thanks and reply on this Please
Username: Plymouth
Post Number: 1218
Sorry Rtap if i hurt you.
Without joke Sorry
Username: Plymouth
Post Number: 1232
King
I retry my first post and that does not work any more. it seems i have same problem as all.
Now i tried to delete sat and autoscan and i lost many channel, after i do a blind scan and many channel is lost. I decided to doing a hard reboot and boom "no channel on box"
I reload last bin and scan all sat again and come back with the issue.
Username: Plymouth
Post Number: 1235
OK with autoscan on all sat, all is come back and all channel is there.
