Bronze Member Username: BtePost Number: 18 Registered: Nov-07 | hi guys i need serious help i was converting my 2500 to 2700 clone to PUFF and i have been stuck on (F) forever plz help asap! | ||
Bronze Member Username: BtePost Number: 20 Registered: Nov-07 | plz help | ||
Gold Member Username: JuanchoDe los cerros mas alto..., BINDURABLE. Post Number: 2702 Registered: Dec-06 | the F. mean yoyu have now a PUFF receiver. now use Bl loader 1.4 and the when first F shows load jvvh_258_Nkk_Puff.bin. here it is posted for who modds the NKK bins, look for Nikk Mty post#1847 here.https://www.ecoustics.com/electronics/forum/home-video/464036.html |
Bronze Member Username: BtePost Number: 27 Registered: Nov-07 | thx for reply, now i loaded the bin. puff flashes twices and stays on f for 10 seconds and restarts. | ||
Bronze Member Username: BtePost Number: 28 Registered: Nov-07 | the reciver never comes to "ON" just stays on F now plz help | ||
Gold Member Username: JuanchoDe los cerros mas alto..., BINDURABLE. Post Number: 2704 Registered: Dec-06 | then you have to come back to 253 Canam 640 kb bin and start over again.or just load a chanel list if you any ,using Gtromloader 27.02 load it . are you sure that you have only F no F. the last one mean you have to load lzma bin..tell which one do you load , I will post the boot
Bronze Member Username: BtePost Number: 30 Registered: Nov-07 | yes i checked agian and it only F and i tried uploading channel list using channel master it doesnt work. | ||
Gold Member Username: JuanchoDe los cerros mas alto..., BINDURABLE. Post Number: 2705 Registered: Dec-06 | then you have to load boot 60 with loader converter to 2700 . when the knight riders(----) no turn off stb, use nikk 258 nkk PUFF bin and load using 1.4 loader | ||
Bronze Member Username: BtePost Number: 31 Registered: Nov-07 | u mean re-install puff 1) Using 2700 to 2500 loader: use boot60 with (boot not bin) then download 2) using blacklist updater 1.4 download jvvh fortec-pansat canAm puff 253(640k) bin 3)download nikk 258 nkk PUFF bin right?? |
Gold Member Username: NydasPost Number: 9422 Registered: Jun-06 | Everything you need for 2500/Flu to 2700 conversion in one package. Instructions included. Either b75 boot or PUFF boot or PUFF_LZMA boot and matching BINs http://public.box.net/2500_full_kit Read the instructions properly in the section you have chosen. PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS. The revert to 2500 is included in the b75 directory as a subdirectory and in th eother two directories as Boot60 subdurectory. |
Gold Member Username: JuanchoDe los cerros mas alto..., BINDURABLE. Post Number: 2706 Registered: Dec-06 | some receivers do this when they don't take the boot60 as they could 1 Rebootings every 10 minutes over and over. 2)some show a cero then 5 after the F for about 1 or 2 minutes without stop. solucion install boot60 again and start over |
Bronze Member Username: BtePost Number: 32 Registered: Nov-07 | nalin should i revert back to 2500 or is there something else i can do to fix the F that appears when ever i turn on my reciever thx. | ||
Bronze Member Username: BtePost Number: 33 Registered: Nov-07 | ok thx i will do as u say Juan Ramirezone | ||
Gold Member Username: NydasPost Number: 9425 Registered: Jun-06 | The 2500/FLU are very tolerant. You can revert and start all over - I find it the best. ALWAYS WAIT, W A I T W A I T - W A I T |
