Looking for a HO ALT
Username: Kingandsons07
Lincoln, Nebraska U.S.A
Post Number: 897
OK I'm looking for the biggest alt for a 01 Monte Carlo 3.4L V6. set up will be one 15" on a 3250.1. maybe later on two 15" HW and two 3250.1 and what batts should i use? and will be for daily/comp thanks
Username: Insearchofbass
Post Number: 8535
does your monte look similar to the 1995 monte carlo I had if so I had a system in that car
Post Number: 8536
ok I just looked it up and while it doesnt look the same on the outside the interior looks to have a similar layout you might have a hard time finding more than a 200 to 220 amp alt for that car...a few years back I looked for an upgraded alt for my monte z34 (3.4 v6) and I dont think I found any larger than that range...if your seats fold down 60/40 like mine did youll be able to fire one 12 into the cab without anything getting in the way...my 12 firing that way slammed at 36 hz and on music I could shake the steering wheel and the head unit that was mounted securely in the dash...so Id suggest one slammin 12 in there...if you fire backward be prepare for alot of back deck movement but it might be louder than firing forward into the cab
Username: Kingtutus
Lincoln, Nebraska U.s.a
Post Number: 183
he is going to do one 18" fi q for now then when he gets some money he will be putting 2 15" hw in their with 2 3250 on them
Post Number: 899
i never had a 15" so i'm hopein to try they out
Username: Nd4spd18
Northwest PA
Post Number: 6923
http://www.db-starter-alternator.com/Items/8234-5-200amp%20-%20grand%20prix?&caS KU=8234-5-200amp%20-%20grand%20prix&caTitle=CENTURY%20GRAND%20PRIX%20HIGH%20AMP% 20OUTPUT%20ALTERNATOR%2099%2000%2001%20%208234-5
Post Number: 905
thanks M.S
Username: Nd4spd18
Northwest PA
Post Number: 6942
That is a very good company BTW my alternator is from there and it's very good, as is their customer service.
Username: Big_edge_head
Milwaukee, Wisconsin MY SUBS GET ...
Post Number: 1722
How long have you owned you DB alt. M.S.?
Username: Nd4spd18
Northwest PA
Post Number: 6944
Since last summer.
Post Number: 1723
I see. I need to buy one from them in the next month or so for a school project. It's kind of my excuse to buy one.
Username: Nd4spd18
Northwest PA
Post Number: 6946
Nice. I used "installing a system" as my seinor project in HS........
