try it: All viewsat box Go to Code menu Select Nagra and on Dish 01 06 00 Dish 00 01 00 dish 01 01 00 Delete this 3 provider one by one with F3 on remote no need to delete keys switch off 10 secs on back panel and load last bin for your box turn autoroll on Keep on Bin and autoroll regenerete keys Resolve problem with lost channel , autoroll, freeze and search signal
Thats erase bad data in the box For box who lost channel and sat setup ENJOY TV
TESTED and work fine New issue for problem on Viewsat Thanks
Do a blind scan on your sat after for recover all channel Because some new freq are provide Dont do a factory reset and factory bin No need it
if you delete the key like plymouth posted, you will need to reload the latest bin like he posted as well.
sometimes vs would lose signal, after hard reboot, switch off/on from the back should able to reset it.
if not, go to antenna settings, make sure everything there is still correct.
signal meter is more likely to be voltage feeding the lnbs, quality meter is more important, if there is no quality at all, there will no tvs.
you can always do a fac reset=load fac bin/latest bin, if still not work, the last option is fac default which wipes everything to original state=load fac bin/set fac default/load latest bin/
Always switch off from the back after new bin load completed, and wait a few minutes before reboot, this helps the new bin and auto roll to kick in.
PLYMOUTH after deleting the porivider and after flashing with the latest 08-03-11u i can not see 01 06 provider only got 0101 and 0001 i lost all the pictures. work fine with bev but not dn
from thetotal it was working great some autoroll a nd little freez made me do what you suggested deleting the 3 provider. and that's where i screwed up .
