New sub
Username: Jeffkock
Post Number: 139
I have a MCD1000 which is 1100 watts rms stable at 1ohm and i am looking to get a new sub i have 2 alpine type-r and want one sub it would be pimp to just get a 10 to save a little space does any one have any sugestions for something that will pound under $450
Username: Loudazzaltima
Brooklyn, NY
Post Number: 32
orion hcca subs 2000wrms 4000max, digital dynamics,
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2304
Digital Dynamics? Do you mean Digital Designs?
Anyways, what are you looking for? Strait up loud or do you want a good mix of sound quality and SPL?
Username: Hittin1
LakeCharles LA., La
Post Number: 52
wtf?
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2305
What? Are you confused by the question? Do you want a sub that is purely loud or do you want one that gets fairly loud and still sounds good?
Username: Hittin1
LakeCharles LA., La
Post Number: 53
lol... I was referring to what The post above you read? I posted same time you did.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2306
Gotcha...my question remains the same tho if you want help picking something out
Username: Hittin1
LakeCharles LA., La
Post Number: 55
LMAO... I'm not the one who originally posted.
Username: Chaunb3400
All he does is catch t..., Alabama U.S.
Post Number: 14075
Chauncey's Alpha
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2307
Wow, reading > me
Sorry about that. I guess I am not paying much attention!
Username: Hittin1
LakeCharles LA., La
Post Number: 57
lol... not a prob!
Soooooo. Jeff wants to not use the type r's and find a 10" in. sub that handles 1100 wrms... right?
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2312
That;s what I am getting out of it. I would say a AQ HDC3
Username: Dakangofkrunk16
Boca Raton, Florida
Post Number: 1323
Fi SSD - SQL (flatwindcoil and BP Power Options)
Fi Q - SQ (BP Power just to be safe)
Fi BL - SPL ( get this if you also might plan on adding more watts to, in future
AQ HDC3 - Not exactly Sure.. But a very good Sub
Maybe a Ascendant Audio Havoc Series 12... No 10's but a 12 still would save space
SSA Audio Icon 10inch Rated fro 900 rms, but it can do more..If everything is set right
Thats all i can think of as of now
Oh id also say the RD audio Elite.. But Dual 1.5 ohm forms a 3ohm load and...
Post Number: 14078
Chauncey's Alpha
Username: Hittin1
LakeCharles LA., La
Post Number: 59
Image Dynamics IDQ10V3.D2
RE Audio SX10
audioque HDC3
a few possibilities(not in that order..lol)
all match up good with that strong amp... Love M-Class amps...
Username: Hittin1
LakeCharles LA., La
Post Number: 60
I'll bet it (the Memphis amp) knocked the sh!t out of the type-r's
Username: Prozack52
Cincinnati, 2-D615D4 Dia...
Post Number: 218
level four dc sound lab
Username: Insearchofbass
Post Number: 8502
"That;s what I am getting out of it. I would say a AQ HDC3"
dont do one of those the sq wont be that great down on the low notes
Username: Bernymac
Cambodia
Post Number: 3792
ID MAX
Username: Jeffkock
Post Number: 140
Is The AQ HDC3 2ohm stable
Username: Hittin1
LakeCharles LA., La
Post Number: 95
hold up.... that is a dvc sub... the term "stable" refers to what an amp cam run safetly (ohms).. That sub comes with 2 or 4 ohm voice coils.... for your m-class amp you would need to get the 2 ohm voice coils and wire them in paralell to 1 ohm for your 1 ohm "stable" amp. hope this helps
Username: Jtown
Team RD, Texas
Post Number: 2595
I wouldn't really say the SSD is a SQL woofer, esp with the FLATWIND and BP power option....
Chauncey's Alpha would do you some good. I'd get it if I didn't already have a 12" or if I had the money, I would buy it anyway.}
Username: Nyyfan13
15 MAG USA
Post Number: 9002
My SSD didn't sound bad with just the flatwind coil on it. Sounded better than other subs I've heard.
Username: Jtown
Team RD, Texas
Post Number: 2596
didn't say it sounded bad yanks, just my opinion. I actually had originally planned on going with an SSD copper coil sometime last year, but the sub failed for some unknown reason, so I went with the alpha. glad I changed my mind, instead of keeping the SSD that Scott rebuilt for me.
Username: 420alldaylong
Post Number: 3418
SoundSplinter RL-p
