Username: Chip_la Post Number: 42 Registered: Oct-07
Friday, March 21, 2008 - 19:52 GMT Hi Could someone give me the sat. settings for echo 8-10.freq.line power.ports,etc.I can't seem to get them right. I used get some channels but not any longer. Thanks chip
Username: Plymouth Quebec city,
Quebec
Post Number: 1083 Registered: Jan-08
Friday, March 21, 2008 - 21:40 GMT Explained it: I used get some channels but not any longer.
Username: Madflea168 Post Number: 357 Registered: Jan-08
Friday, March 21, 2008 - 23:17 GMT for 110/119 the settings are the same except the port on the switch. 119 on port #1, 110 on port #2. both uses freq 11250, lnb type base on the lnb you use, if from dn use osc-dp. you probably get better signals/quality on 119 from 12239 rather than 12224. good luck.
