Silver Member Username: KillswitchjdPost Number: 690 Registered: Apr-06 | I have a 300 amp alternator from excessive amperage for the 3.4 L chevy engine that I had in my 98 buick lesabre. This alternator should fit all the cars with the 3.4 L engine in it, including many different models. I dont have a pic now, but it looks like a beefy alternator. I will supply a pic if someone makes a reasonable offer or if I get time. Im looking for at least a couple hundred |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 13384 Registered: Jul-05 | Pics would be nice...is it a direct bolt in?? |
Silver Member Username: KillswitchjdPost Number: 699 Registered: Apr-06 | should be , yes. It was on my car. I will get pics up as soon as I can |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 13398 Registered: Jul-05 | Im still interested..please get pics |
Silver Member Username: KillswitchjdPost Number: 716 Registered: Apr-06 | sorry, been really busy. I can promise it will ship within two business days after payment is received. If interested post an offer, again a 300 amp alternator from excessive amperage, 3.4 liter chevy (gm) engine found in alot of cars. |
Gold Member Username: Nd4spd18Northwest PA Post Number: 5930 Registered: Jul-06 | You sure thats a direct bolt it? Looks like a CS144 aka large case alt....... usually the rear mounting bracket doesn't fit tight on cars that don't come with that alt? |
Silver Member Username: KillswitchjdPost Number: 719 Registered: Apr-06 | like I said, on my 3.4L in my buick lesabre it was a direct bolt in. I cant say for sure if it will fit any other cars |
Silver Member Username: KillswitchjdPost Number: 720 Registered: Apr-06 | I can measure it if someone has the standard or some comparison. |
Gold Member Username: JtownTeam Revolution, Texas Post Number: 1930 Registered: Mar-07 | too bad it's not for a 4.3L '01 |
Silver Member Username: KillswitchjdPost Number: 726 Registered: Apr-06 | bump.. no one has a need for this? hate looking at it just sit in my room |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 13790 Registered: Jul-05 | How much?? If you could find out it it would fit a 99-04 Pontiac Grand AM, i would snatch it up asap |
Gold Member Username: Nd4spd18Northwest PA Post Number: 6126 Registered: Jul-06 | Ok for one thing that car uses a CS130D alternator. For another, alternators are not as interchangable as you guys think........ even some that would physically fit could have the wrong electronics built in. What I'm getting at, is that alt won't fit every car with a 3.4L engine. Heres one that would fit that Grand Am: http://www.db-starter-alternator.com/Items/8228-7-200amp%20-%20alero?sck=7770103 |
Gold Member Username: AdddisorderPalm Beach, Florida Post Number: 5907 Registered: Jan-06 | ^^^thats what i try to tell everyone MS then they give me crap like why not it looks like it will bolt up and dont take my word for it. |
Gold Member Username: Van_manBoston South, MA Post Number: 3404 Registered: Mar-06 | Nice deal, if it works for your car. btw, even same model, engine vary from year to year. Example. I had a new alt in my 2000 dodge van, and I put a new one in my 2001 dodge van. Same 3.9 engine, but difffrent alts. Plug in is diffrent as well as the ring terminals. I had to do some mods to get it in there, cause I have a life time on the 2000 alt and made it work in the 2001 with mods. So now my 2001 has a life time warranty. |
Silver Member Username: KillswitchjdPost Number: 734 Registered: Apr-06 | bump... no one has a 98 buick lesabre? |
Gold Member Username: SomedonniedudeIllinois United States Post Number: 1167 Registered: May-07 | Chancey what motor does that Grand Am have?? I know my sisters Am GT had a 3.4l if thats worth anything, and it was a 00'. |
Platinum Member Username: Chaunb3400All he does is catch t..., Alabama U.S. Post Number: 14080 Registered: Jul-05 | yea 3.4 |
Silver Member Username: KillswitchjdPost Number: 737 Registered: Apr-06 | you would have to contact EA I guess.... he should be able to tell you for sure. I think he is in the same state as you chauncey? I dont remember where he was based... |
Gold Member Username: Nd4spd18Northwest PA Post Number: 6911 Registered: Jul-06 | Marcs example is a good one, but sometimes even 2 alts that look exactly the same still do not have the same electronics built in. |
