RMS and PEAK power
Username: Playaward
Breman, Georgia USA
Post Number: 21
I was wondering if I buy a MTX Thunder 2400 watt mono block amp and rms is 800 watts,will this give my sub 2400 watts ate not ???
Username: Southernrebel
Monroe, Louisiana 2 DD3515s, 2...
Post Number: 6216
No, if the amp is rated 800w RMS it will give you 800w.
What is this amp's actual model #?
What subs do you have?
Username: Playaward
Breman, Georgia USA
Post Number: 22
kicker solo x 12"
Username: Insearchofbass
Post Number: 8641
the sellers like to show the max rating to fool the buyers into thinking its more power...rms is what matters
Username: Playaward
Breman, Georgia USA
Post Number: 23
so i should be looking for a high rms rather than the amps peak power ?? I was considering buying a hifonics 2000 watt amp or maybe the collosis amp made by hifonics.
Username: Denali_on_22s
The kids love my rhyme...
Post Number: 4815
you better have the charging system to support it...
Username: Tejcurrent
Post Number: 1215
A kicker 2500 would be a good match or that sub imo, but you really need a stout charging system once you get into that much power. New alternator and a 2nd battery.
Username: Hittin1
LakeCharles LA., La
Post Number: 96
The hifinics bxi 2006d will work Bobby... It is Not the best amp for that sub, but it works great if you have a budget.That is what i'm running on each of my solo x's and you saw the vid... It really moves em. but you will need HO Alt. and 0 ga. and big 3 and audio dry cell battery to properly feed that system.
