Help explorer and the bins
Username: Cartier1
Post Number: 1780
i did ask this question in the past but i never fallowed due to a trip.
why all the bins are opened with the logo explorer . for this reason my friend can not flash his receiver , even using his usb flahs driver his bins are with explorer.
what to do> thanx
Username: Kirankumar
NO Bashing
Post Number: 2240
all my bins are downloaded as zip file and when i unzip it it is in the form of an stb file,so i don't know what you are doing wrong
NO Bashing
Post Number: 2241
would be a good idea to download a fresh free copy of winrar and unzip it
then download a bin at the desktop and hit unzip here and see what happens
Username: Flu_guy
Post Number: 78
Cartier1:
I am not exactly sure what you mean by "Logo Explorer but here goes...
Bins are usually opened with a loader, specific to your receiver like "BLACKLIST UPDATER.EXE" for the Pansats. However, you may be using Windows Explorer to unzip the bin and locate it in the same directory as the loader so that the .bin can be found by the loader easily. You might also be using Windows Explorer to find and execute the loader if there is no shortcut available. You could also use "My Computer" do all this instead, in fact there are lots of ways to run the thing.
I might of course have the wrong end of the stick altogether, in which case I apologise, perhaps someone else can explain it. If you could supply more details it would also be helpful.
Htiek
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 1187
Install winrar and use that, this the best unzip. Never opening with Explorer that corrupt files.
When you install it just to make unzip by default. Double clic on and slip the unzip file where you went
Username: Nydas
Post Number: 9426
The files get associated with Explorer. If they get associated with Internet explorer it is undesireable.
Using winrar or winzip to unzip, you will cure th eproblem. In fact new association will be saved as soon as you install one of these.
Username: Cartier1
Post Number: 1781
thank you gentelmen. actually this happen to my friend that he opened a bin using explorer and everything as nalin said was associated with explorer now . it does not matter if u install fresh copy of winzip or winrare. when u unzip them the bins carry the logo of explorer, so he never was able to flash it to his stb.
im mot sure what way to clean up the explorer from his bins .
i tried to go to recovery and set his computer to a recovery point before this things happen to him but without success.
the last thing to do is format and install an other copy of windows but we are trying to avoid that ,
again thanx for your response guys and hopefully someone with great idea will provide his help ,
Username: Plymouth
Post Number: 1201
Which windows Vista, XP, 2000, Millenium or 98
Username: Cartier1
Post Number: 1782
window xp
Username: Plymouth
Post Number: 1202
Try to uninstall winrar in program manager
and delete in C:program files the winrar file
Download and install Regcleaner on this site:
http://www.clubic.com/telecharger-fiche10573-regcleaner.html
on upper bar choose "tool"and "registry cleanup" and "do them all
choose all item with Ctlr+C and delete in right lower corner
Now reinstall Winrar, it supposed to ask you if you went winrar by default and you do
It supposed to work now.
My syster had same problem with is XP
Username: Metallica
Post Number: 423
Hey Cartier did you remember last time you are asking this same question???
did you remember that day?? if you do go back to that day and find that Archive in this forum...i saw Dantetn and Doreen have give you a lot of INFOR how to fix that problem...go back and check it out cause i have no clue how to fix that ...Good Luck.
Username: Plymouth
Post Number: 1203
Hi Metallica how are you
Username: Metallica
Post Number: 425
Hi Plymouth.
i'm doing fine man..watching p@rn right now..LOL
how about you?? are you watching p@rn right now too..
Username: Plymouth
Post Number: 1204
No i try to solution some problem on double channel on viewsat, i found that because the frquency assigned by the bin is not the same like blind scan.
we just to choose this channel on both one after the other and that come automatically delete one of two. because we have some post on it.
It's not really a problem
autoscan give me 133 channel
blind scan give me 351 channel
It's better to blind scan
because Nalin say dont do blind scan.
Username: Nydas
Post Number: 9440
Plymouth: I have always advocated Blind Scan in preference to other types of scans.
Apparently there has been a No-No on Blind Scan on Viewsat Ultra for quite a while - I don't know when and how it started, but it did originate from somebody very reliable here. Since I do not have a Viewsat Ultra, i just accepted the information.
If you are saying Blind Scan works and is OK, I will accept that.
Username: Plymouth
Post Number: 1210
Nalin
When we do a autoscan we scan just the TP is furnish by the bin and in the sat freq tp, if this info are change by provider like polirarisation the scan dont see these channels and you lost some channel.
When you do a blind scan all freq is scan on "V" and "H and each channel too.
Thats why all channel is found on this one
Thanks
