Username: Dubmc23 Rapid City,
SD
Post Number: 223 Registered: Sep-07
Wednesday, March 19, 2008 - 00:24 GMT i plan to have 2 15" kicker cvr's...because the 15's wont fit in my trunk...where would i be able to go to get a box built for that?
Username: Frkkevin Resonant Engineering...,
Fort Worth...
Email
Post Number: 4789 Registered: Nov-05
Wednesday, March 19, 2008 - 00:25 GMT anyone who builds boxes can do it.. its nothing special man up and build it yourself .. plenty of people here will help you with a design
SD
Post Number: 224 Registered: Sep-07
Wednesday, March 19, 2008 - 00:27 GMT lol k...i have absolutely 0 woodworking ability so ill prlly have my friend do it...where could i get specs? i have a 98 honda civic sedan
Fort Worth...
Email
Post Number: 4790 Registered: Nov-05
Wednesday, March 19, 2008 - 00:48 GMT specs for what? take out the backseat and build a flat platform for the box to sit on.. measure up and see what dimensions you have to work with and post them up here and well design a box 7^3ft @ 35hz is what i'd do.. if you want more lows we can design for it
Username: Rickvl VancouverCanada
Post Number: 6 Registered: Feb-08
Wednesday, March 19, 2008 - 04:40 GMT I have a Mtx MZS1204 sub in a sealed box at 1.25 ft3 that Mtx recomends.Is it possible to port this box or should I just stick with sealed.Right now as it is it sounds like it echos and kind of hollow and a bit boomy,would polyfill help? Thanks
